Hi team
We are using TUSB8044A hub in one of our application can we use USB 2.0 and USB3.0 connection form different downstream port simultaneously ?
Does data rate of one port will be limited by data rate available on another port ?
Hi team
Hi Abhishek,
USB 3.0 and USB 2.0 connections are simultaneous and separate within the hub. The buses are run on entirely different signals within the system and there is no translation between the two. A USB 3.0 device or host connected with a USB 2.0 cable will drop to USB 2.0 signalling as part of backward compatibility.
JMMN
