Dear Sir,
1,Can use HD3SS3412 for 12G-SDI Switch? The BW of HD3SS3412 is 8 Gghz.But the datasheet said it can switch 12Ghz signal.
2,I also need fan-out device for 12G-SDI signal .Is ther any recommendation?
Dear Sir,
1: TMUXHS4212 should be good for 12G
2: can you explain for fan out device?
Thanks for your reply。
1.What is the different between TMUXHS4212 and TMUXHS4212A?
2.Like splitter device,I need to make 1 differential pair 12G SDI signal into 3 differential pair signal。
