Other Parts Discussed in Thread: DP83867E
Hi TI team,
My board is using 2 x DP83867E phys. How do I verify the EYE diagram at the the end of the cable.
I am assuming that I have to use 2 Phys connecting via a CAT6. Configure the master phy to generate continuous PRBS packet and configure the slave phy to function as a LOOPBACK then probe MDI channel A of slave phy.( applying the test only to Channel A)
Is that the right way to verify the EYE at the end of the cable?
Also can you please provide the register programming stpes and values to achieve above?
Many Thanks,
Bahram
