Hi FPD Link Experts,
Are you able to share information on the thresholds between the IDx levels? My customer is seeing some boards be at 0x1E instead of 0x1C.
It would be helpful to know for 0x1C you need to be at 502mV +/- x mV.
Thanks!
Reed
Thanks!
Reed
Hi Reed,
We dont have the thresholds to share. If this issue happens, please check the IDX reference voltage and the resistor tolerance to make sure they are with in datasheet spec.
What is the measured voltage at IDX pin when the issue happens?
Charley Cai
Hi Charley,
The resistors are incorrect and being modified in the next board revision to match datasheet requirements. The voltage is 526mV.
Please advise.
Reed
Hi Reed,
In this case, i would suggest the customer to use the correct resistor values.
Charley Cai
