TMDS181: No signal output when worked in 4K@60
Part Number: TMDS181
Hi David,
I meet the same issue  when I used 4K@60.
https://e2e.ti.com/support/interface/f/138/t/947429?tisearch=e2e-quicksearch&keymatch=TMDS181
How to fix this issue in finally?
    Are you able to see the video with 4k@30?
    Can you please share your schematic and TMDS181 page 0 and page 1 register dump? To access page 1 register, please write 0x01 to register 0xFF first, and then dump register from 0x00 to 0xB1.
    Can you also probe the TMDS181 clock output and verify the clock out frequency is 150MHz for 4k@60?
    David
  • Hi David ,
    Thanks your quickly response.
    Yes ,4K@30 is ok.
    Please refer to the attachment for schematic and register dump.
    I upload " Register_TMDS181_4K@30" and "Register_TMDS181_4K@60" in the attachment.
    BTW,I have tried to configure the function mode to all of below modes and the termination ( 75 Ω to 150 Ω) for HDMI TX ,but the 4k@60 still can't work.
    DEV_FUNC_MODE. This field selects the device working function mode.
    00 – Redriver mode: 250 Mbps – 3.4 Gbps
    01 – Automatic redriver to retimer crossover at 1.0 Gbps (default)
    10 – Automatic retimer when HDMI2.0a based upon
    TMDS_CLOCK_RATIO_STATUS
    11 – Retimer mode across full range 250 Mbps to 6 Gbps
    distribute_output_card.pdf
    Register_TMDS181_4K@30.txt
    page 0:
    ~ # i2c_read 0 0xB9 0x0 0xff 0x1 0x1 0x1
    *** Board tools : ver0.0.1_20121120 ***
    [debug]: {source/utils/cmdshell.c:167}cmdstr:i2c_read
    i2c_num:0x0, dev_addr:0xb9; reg_addr:0x 0; reg_addr_end:0xff; reg_width: 1; data_width: 1; reg_step:0x 1.
    0x0 0x54
    0x1 0x4d
    0x2 0x44
    0x3 0x53
    0x4 0x31
    0x5 0x38
    0x6 0x31
    0x7 0x20
    0x8 0x1
    0x9 0x2
    0xa 0xb1
    0xb 0x0
    0xc 0x0
    0xd 0x0
    0xe 0x0
    0xf 0xf
    0x10 0x0
    0x11 0x0
    0x12 0x0
    0x13 0x0
    0x14 0x0
    0x15 0x80
    0x16 0x0
    0x17 0x60
    0x18 0x0
    0x19 0x0
    0x1a 0xc7
    0x1b 0x2
    0x1c 0xd
    0x1d 0x8
    0x1e 0x8
    0x1f 0x0
    0x20 0xa
    0x21 0x0
    0x22 0x0
    0x23 0x0
    0x24 0x0
    0x25 0x0
    0x26 0x0
    0x27 0x0
    0x28 0x0
    0x29 0x0
    0x2a 0x0
    0x2b 0x0
    0x2c 0x0
    0x2d 0x0
    0x2e 0x0
    0x2f 0x0
    0x30 0x0
    0x31 0x0
    0x32 0x0
    0x33 0x0
    0x34 0x0
    0x35 0x0
    0x36 0x0
    0x37 0x0
    0x38 0x0
    0x39 0x0
    0x3a 0x0
    0x3b 0x0
    0x3c 0x0
    0x3d 0x0
    0x3e 0x0
    0x3f 0x0
    0x40 0x0
    0x41 0x0
    0x42 0x0
    0x43 0x0
    0x44 0x0
    0x45 0x0
    0x46 0x0
    0x47 0x0
    0x48 0x0
    0x49 0x0
    0x4a 0x0
    0x4b 0x0
    0x4c 0x0
    0x4d 0x0
    0x4e 0x0
    0x4f 0x0
    0x50 0x0
    0x51 0x0
    0x52 0x0
    0x53 0x0
    0x54 0x0
    0x55 0x0
    0x56 0x0
    0x57 0x0
    0x58 0x0
    0x59 0x0
    0x5a 0x0
    0x5b 0x0
    0x5c 0x0
    0x5d 0x0
    0x5e 0x0
    0x5f 0x0
    0x60 0x0
    0x61 0x0
    0x62 0x0
    0x63 0x0
    0x64 0x0
    0x65 0x0
    0x66 0x0
    0x67 0x0
    0x68 0x0
    0x69 0x0
    0x6a 0x0
    0x6b 0x0
    0x6c 0x0
    0x6d 0x0
    0x6e 0x0
    0x6f 0x0
    0x70 0x0
    0x71 0x0
    0x72 0x0
    0x73 0x0
    0x74 0x0
    0x75 0x0
    0x76 0x0
    0x77 0x0
    0x78 0x0
    0x79 0x0
    0x7a 0x0
    0x7b 0x0
    0x7c 0x0
    0x7d 0x0
    0x7e 0x0
    0x7f 0x0
    0x80 0x0
    0x81 0x0
    0x82 0x0
    0x83 0x0
    0x84 0x0
    0x85 0x0
    0x86 0x0
    0x87 0x0
    0x88 0x0
    0x89 0x0
    0x8a 0x0
    0x8b 0x0
    0x8c 0x0
    0x8d 0x0
    0x8e 0x0
    0x8f 0x0
    0x90 0x0
    0x91 0x0
    0x92 0x0
    0x93 0x0
    0x94 0x0
    0x95 0x0
    0x96 0x0
    0x97 0x0
    0x98 0x0
    0x99 0x0
    0x9a 0x0
    0x9b 0x0
    0x9c 0x0
    0x9d 0x0
    0x9e 0x0
    0x9f 0x0
    0xa0 0x0
    0xa1 0x0
    0xa2 0x0
    0xa3 0x0
    0xa4 0x0
    0xa5 0x0
    0xa6 0x0
    0xa7 0x0
    0xa8 0x0
    0xa9 0x0
    0xaa 0x0
    0xab 0x0
    0xac 0x0
    0xad 0x0
    0xae 0x0
    0xaf 0x0
    0xb0 0x0
    0xb1 0x0
    0xb2 0x0
    0xb3 0x0
    0xb4 0x0
    0xb5 0x0
    0xb6 0x0
    0xb7 0x0
    0xb8 0x0
    0xb9 0x0
    0xba 0x0
    0xbb 0x0
    0xbc 0x0
    0xbd 0x0
    0xbe 0x0
    0xbf 0x0
    0xc0 0x0
    0xc1 0x0
    0xc2 0x0
    0xc3 0x0
    0xc4 0x0
    0xc5 0x0
    0xc6 0x0
    0xc7 0x0
    0xc8 0x0
    0xc9 0x0
    0xca 0x0
    0xcb 0x0
    0xcc 0x0
    0xcd 0x0
    0xce 0x0
    0xcf 0x0
    0xd0 0x0
    0xd1 0x0
    0xd2 0x0
    0xd3 0x0
    0xd4 0x0
    0xd5 0x0
    0xd6 0x0
    0xd7 0x0
    0xd8 0x0
    0xd9 0x0
    0xda 0x0
    0xdb 0x0
    0xdc 0x0
    0xdd 0x0
    0xde 0x0
    0xdf 0x0
    0xe0 0x0
    0xe1 0x0
    0xe2 0x0
    0xe3 0x0
    0xe4 0x0
    0xe5 0x0
    0xe6 0x0
    0xe7 0x0
    0xe8 0x0
    0xe9 0x0
    0xea 0x0
    0xeb 0x0
    0xec 0x0
    0xed 0x0
    0xee 0x0
    0xef 0x0
    0xf0 0x0
    0xf1 0x0
    0xf2 0x0
    0xf3 0x0
    0xf4 0x0
    0xf5 0x0
    0xf6 0x0
    0xf7 0x0
    0xf8 0x0
    0xf9 0x0
    0xfa 0x0
    0xfb 0x0
    0xfc 0x0
    0xfd 0x0
    0xfe 0x0
    0xff 0x0
    [END]
    Page 1:
    ~ # i2c_write 0 0xB8 0xff 0x1
    [debug]: {source/utils/cmdshell.c:167}cmdstr:i2c_write
    dev_addr:0xb8; reg_addr:0xff; reg_value:0x 1; reg_width: 1; data_width: 1.
    [END]
    0x0 0xc3
    0x1 0x1
    0x2 0x3f
    0x3 0x0
    0x4 0xa0
    0x5 0x0
    0x6 0x0
    0x7 0x0
    0x8 0x4
    0x9 0x0
    0xa 0x0
    0xb 0x33
    0xc 0x0
    0xd 0x0
    0xe 0x11
    0xf 0x0
    0x10 0xf
    0x11 0x0
    0x12 0x0
    0x13 0x7
    0x14 0x0
    0x15 0x0
    0x16 0x0
    0x17 0x0
    0x18 0x0
    0x19 0x0
    0x1a 0x0
    0x1b 0x0
    0x1c 0x0
    0x1d 0x0
    0x1e 0x0
    0x1f 0x0
    0x20 0x0
    0x21 0x0
    0x22 0x0
    0x23 0x0
    0x24 0x0
    0x25 0x0
    0x26 0x0
    0x27 0x0
    0x28 0x0
    0x29 0x0
    0x2a 0x0
    0x2b 0x0
    0x2c 0x0
    0x2d 0x0
    0x2e 0x0
    0x2f 0x0
    0x30 0x7
    0x31 0x30
    0x32 0x8
    0x33 0x0
    0x34 0x0
    0x35 0x0
    0x36 0x0
    0x37 0x0
    0x38 0x8
    0x39 0x0
    0x3a 0x8
    0x3b 0x8
    0x3c 0x4
    0x3d 0x6
    0x3e 0x0
    0x3f 0x0
    0x40 0x80
    0x41 0x80
    0x42 0x80
    0x43 0x80
    0x44 0xff
    0x45 0x0
    0x46 0x0
    0x47 0x0
    0x48 0xff
    0x49 0x3f
    0x4a 0x3f
    0x4b 0xff
    0x4c 0x3
    0x4d 0x10
    0x4e 0x33
    0x4f 0x70
    0x50 0x0
    0x51 0x0
    0x52 0x0
    0x53 0x0
    0x54 0x0
    0x55 0x0
    0x56 0x0
    0x57 0x0
    0x58 0x0
    0x59 0x0
    0x5a 0x0
    0x5b 0x0
    0x5c 0x40
    0x5d 0x40
    0x5e 0x40
    0x5f 0x40
    0x60 0x0
    0x61 0x0
    0x62 0x0
    0x63 0x0
    0x64 0x0
    0x65 0x0
    0x66 0x0
    0x67 0x0
    0x68 0x0
    0x69 0x0
    0x6a 0x0
    0x6b 0x0
    0x6c 0x0
    0x6d 0x0
    0x6e 0x0
    0x6f 0x0
    0x70 0x0
    0x71 0x0
    0x72 0x0
    0x73 0x0
    0x74 0x0
    0x75 0x0
    0x76 0x0
    0x77 0x0
    0x78 0x0
    0x79 0x0
    0x7a 0x0
    0x7b 0x0
    0x7c 0x0
    0x7d 0x0
    0x7e 0x0
    0x7f 0x0
    0x80 0x0
    0x81 0x20
    0x82 0x0
    0x83 0x0
    0x84 0x0
    0x85 0x0
    0x86 0x0
    0x87 0x0
    0x88 0x0
    0x89 0x0
    0x8a 0x0
    0x8b 0x0
    0x8c 0x0
    0x8d 0x0
    0x8e 0x0
    0x8f 0x0
    0x90 0x0
    0x91 0x0
    0x92 0x0
    0x93 0x0
    0x94 0x0
    0x95 0x0
    0x96 0x0
    0x97 0x0
    0x98 0x0
    0x99 0x0
    0x9a 0x0
    0x9b 0x0
    0x9c 0x0
    0x9d 0x0
    0x9e 0x0
    0x9f 0x0
    0xa0 0x0
    0xa1 0x0
    0xa2 0x1
    0xa3 0x0
    0xa4 0x0
    0xa5 0x0
    0xa6 0x0
    0xa7 0x0
    0xa8 0x0
    0xa9 0x0
    0xaa 0x0
    0xab 0x0
    0xac 0x0
    0xad 0x0
    0xae 0x0
    0xaf 0x0
    0xb0 0xbe
    0xb1 0x88
    0xb2 0x0
    0xb3 0x0
    0xb4 0x0
    0xb5 0x0
    0xb6 0x0
    0xb7 0x0
    0xb8 0x0
    0xb9 0x0
    0xba 0x0
    0xbb 0x0
    0xbc 0x0
    0xbd 0x0
    0xbe 0x0
    0xbf 0x0
    0xc0 0x0
    0xc1 0x0
    0xc2 0x0
    0xc3 0x0
    0xc4 0x0
    0xc5 0x0
    0xc6 0x0
    0xc7 0x0
    0xc8 0x0
    0xc9 0x0
    0xca 0x0
    0xcb 0x0
    0xcc 0x0
    0xcd 0x0
    0xce 0x0
    0xcf 0x0
    0xd0 0x0
    0xd1 0x0
    0xd2 0x0
    0xd3 0x0
    0xd4 0x0
    0xd5 0x0
    0xd6 0x0
    0xd7 0x0
    0xd8 0x0
    0xd9 0x0
    0xda 0x0
    0xdb 0x0
    0xdc 0x0
    0xdd 0x0
    0xde 0x0
    0xdf 0x0
    0xe0 0x0
    0xe1 0x0
    0xe2 0x0
    0xe3 0x0
    0xe4 0x0
    0xe5 0x0
    0xe6 0x0
    0xe7 0x0
    0xe8 0x0
    0xe9 0x0
    0xea 0x0
    0xeb 0x0
    0xec 0x0
    0xed 0x0
    0xee 0x0
    0xef 0x0
    0xf0 0x0
    0xf1 0x0
    0xf2 0x0
    0xf3 0x0
    0xf4 0x0
    0xf5 0x0
    0xf6 0x0
    0xf7 0x0
    0xf8 0x0
    0xf9 0x0
    0xfa 0x0
    0xfb 0x0
    0xfc 0x0
    0xfd 0x0
    0xfe 0x0
    0xff 0x1
    [END]
    Register_TMDS181_4K@60.txt
    Page 0:
    0x0 0x54
    0x1 0x4d
    0x2 0x44
    0x3 0x53
    0x4 0x31
    0x5 0x38
    0x6 0x31
    0x7 0x20
    0x8 0x1
    0x9 0x2
    0xa 0x33
    0xb 0x18
    0xc 0x0
    0xd 0x0
    0xe 0x0
    0xf 0xf
    0x10 0x0
    0x11 0x0
    0x12 0x0
    0x13 0x0
    0x14 0x0
    0x15 0x80
    0x16 0x0
    0x17 0x70
    0x18 0x0
    0x19 0x0
    0x1a 0xc5
    0x1b 0x2
    0x1c 0x1
    0x1d 0x8
    0x1e 0x8
    0x1f 0x0
    0x20 0xa
    0x21 0x0
    0x22 0x0
    0x23 0x0
    0x24 0x0
    0x25 0x0
    0x26 0x0
    0x27 0x0
    0x28 0x0
    0x29 0x0
    0x2a 0x0
    0x2b 0x0
    0x2c 0x0
    0x2d 0x0
    0x2e 0x0
    0x2f 0x0
    0x30 0x0
    0x31 0x0
    0x32 0x0
    0x33 0x0
    0x34 0x0
    0x35 0x0
    0x36 0x0
    0x37 0x0
    0x38 0x0
    0x39 0x0
    0x3a 0x0
    0x3b 0x0
    0x3c 0x0
    0x3d 0x0
    0x3e 0x0
    0x3f 0x0
    0x40 0x0
    0x41 0x0
    0x42 0x0
    0x43 0x0
    0x44 0x0
    0x45 0x0
    0x46 0x0
    0x47 0x0
    0x48 0x0
    0x49 0x0
    0x4a 0x0
    0x4b 0x0
    0x4c 0x0
    0x4d 0x0
    0x4e 0x0
    0x4f 0x0
    0x50 0x0
    0x51 0x0
    0x52 0x0
    0x53 0x0
    0x54 0x0
    0x55 0x0
    0x56 0x0
    0x57 0x0
    0x58 0x0
    0x59 0x0
    0x5a 0x0
    0x5b 0x0
    0x5c 0x0
    0x5d 0x0
    0x5e 0x0
    0x5f 0x0
    0x60 0x0
    0x61 0x0
    0x62 0x0
    0x63 0x0
    0x64 0x0
    0x65 0x0
    0x66 0x0
    0x67 0x0
    0x68 0x0
    0x69 0x0
    0x6a 0x0
    0x6b 0x0
    0x6c 0x0
    0x6d 0x0
    0x6e 0x0
    0x6f 0x0
    0x70 0x0
    0x71 0x0
    0x72 0x0
    0x73 0x0
    0x74 0x0
    0x75 0x0
    0x76 0x0
    0x77 0x0
    0x78 0x0
    0x79 0x0
    0x7a 0x0
    0x7b 0x0
    0x7c 0x0
    0x7d 0x0
    0x7e 0x0
    0x7f 0x0
    0x80 0x0
    0x81 0x0
    0x82 0x0
    0x83 0x0
    0x84 0x0
    0x85 0x0
    0x86 0x0
    0x87 0x0
    0x88 0x0
    0x89 0x0
    0x8a 0x0
    0x8b 0x0
    0x8c 0x0
    0x8d 0x0
    0x8e 0x0
    0x8f 0x0
    0x90 0x0
    0x91 0x0
    0x92 0x0
    0x93 0x0
    0x94 0x0
    0x95 0x0
    0x96 0x0
    0x97 0x0
    0x98 0x0
    0x99 0x0
    0x9a 0x0
    0x9b 0x0
    0x9c 0x0
    0x9d 0x0
    0x9e 0x0
    0x9f 0x0
    0xa0 0x0
    0xa1 0x0
    0xa2 0x0
    0xa3 0x0
    0xa4 0x0
    0xa5 0x0
    0xa6 0x0
    0xa7 0x0
    0xa8 0x0
    0xa9 0x0
    0xaa 0x0
    0xab 0x0
    0xac 0x0
    0xad 0x0
    0xae 0x0
    0xaf 0x0
    0xb0 0x0
    0xb1 0x0
    0xb2 0x0
    0xb3 0x0
    0xb4 0x0
    0xb5 0x0
    0xb6 0x0
    0xb7 0x0
    0xb8 0x0
    0xb9 0x0
    0xba 0x0
    0xbb 0x0
    0xbc 0x0
    0xbd 0x0
    0xbe 0x0
    0xbf 0x0
    0xc0 0x0
    0xc1 0x0
    0xc2 0x0
    0xc3 0x0
    0xc4 0x0
    0xc5 0x0
    0xc6 0x0
    0xc7 0x0
    0xc8 0x0
    0xc9 0x0
    0xca 0x0
    0xcb 0x0
    0xcc 0x0
    0xcd 0x0
    0xce 0x0
    0xcf 0x0
    0xd0 0x0
    0xd1 0x0
    0xd2 0x0
    0xd3 0x0
    0xd4 0x0
    0xd5 0x0
    0xd6 0x0
    0xd7 0x0
    0xd8 0x0
    0xd9 0x0
    0xda 0x0
    0xdb 0x0
    0xdc 0x0
    0xdd 0x0
    0xde 0x0
    0xdf 0x0
    0xe0 0x0
    0xe1 0x0
    0xe2 0x0
    0xe3 0x0
    0xe4 0x0
    0xe5 0x0
    0xe6 0x0
    0xe7 0x0
    0xe8 0x0
    0xe9 0x0
    0xea 0x0
    0xeb 0x0
    0xec 0x0
    0xed 0x0
    0xee 0x0
    0xef 0x0
    0xf0 0x0
    0xf1 0x0
    0xf2 0x0
    0xf3 0x0
    0xf4 0x0
    0xf5 0x0
    0xf6 0x0
    0xf7 0x0
    0xf8 0x0
    0xf9 0x0
    0xfa 0x0
    0xfb 0x0
    0xfc 0x0
    0xfd 0x0
    0xfe 0x0
    0xff 0x0
    [END]
    Page 1:
    [END]
    0x0 0xc3
    0x1 0x1
    0x2 0x3f
    0x3 0x0
    0x4 0xa0
    0x5 0x0
    0x6 0x0
    0x7 0x0
    0x8 0x2
    0x9 0x0
    0xa 0x0
    0xb 0x33
    0xc 0x0
    0xd 0x0
    0xe 0x11
    0xf 0x0
    0x10 0xf
    0x11 0x70
    0x12 0x0
    0x13 0x7
    0x14 0x0
    0x15 0x0
    0x16 0x0
    0x17 0x0
    0x18 0x0
    0x19 0x0
    0x1a 0x0
    0x1b 0x0
    0x1c 0x0
    0x1d 0x0
    0x1e 0x0
    0x1f 0x0
    0x20 0x0
    0x21 0x0
    0x22 0x0
    0x23 0x0
    0x24 0x0
    0x25 0x0
    0x26 0x0
    0x27 0x0
    0x28 0x0
    0x29 0x0
    0x2a 0x0
    0x2b 0x0
    0x2c 0x0
    0x2d 0x0
    0x2e 0x0
    0x2f 0x0
    0x30 0x7
    0x31 0x70
    0x32 0x8
    0x33 0x0
    0x34 0x0
    0x35 0x0
    0x36 0x0
    0x37 0x0
    0x38 0x8
    0x39 0x0
    0x3a 0x8
    0x3b 0x8
    0x3c 0x4
    0x3d 0x6
    0x3e 0x0
    0x3f 0x0
    0x40 0x80
    0x41 0x80
    0x42 0x80
    0x43 0x80
    0x44 0xcf
    0x45 0x0
    0x46 0x0
    0x47 0x0
    0x48 0xf8
    0x49 0xf8
    0x4a 0xe0
    0x4b 0xff
    0x4c 0x3
    0x4d 0x20
    0x4e 0x0
    0x4f 0x70
    0x50 0x0
    0x51 0x0
    0x52 0x0
    0x53 0x0
    0x54 0x0
    0x55 0x0
    0x56 0x0
    0x57 0x0
    0x58 0x0
    0x59 0x0
    0x5a 0x0
    0x5b 0x0
    0x5c 0x40
    0x5d 0x40
    0x5e 0x40
    0x5f 0x40
    0x60 0x0
    0x61 0x0
    0x62 0x0
    0x63 0x0
    0x64 0x0
    0x65 0x0
    0x66 0x0
    0x67 0x0
    0x68 0x0
    0x69 0x0
    0x6a 0x0
    0x6b 0x0
    0x6c 0x0
    0x6d 0x0
    0x6e 0x0
    0x6f 0x0
    0x70 0x0
    0x71 0x0
    0x72 0x0
    0x73 0x0
    0x74 0x0
    0x75 0x0
    0x76 0x0
    0x77 0x0
    0x78 0x0
    0x79 0x0
    0x7a 0x0
    0x7b 0x0
    0x7c 0x0
    0x7d 0x0
    0x7e 0x0
    0x7f 0x0
    0x80 0x0
    0x81 0x20
    0x82 0x0
    0x83 0x0
    0x84 0x0
    0x85 0x0
    0x86 0x0
    0x87 0x0
    0x88 0x0
    0x89 0x0
    0x8a 0x0
    0x8b 0x0
    0x8c 0x0
    0x8d 0x0
    0x8e 0x0
    0x8f 0x0
    0x90 0x0
    0x91 0x0
    0x92 0x0
    0x93 0x0
    0x94 0x0
    0x95 0x0
    0x96 0x0
    0x97 0x0
    0x98 0x0
    0x99 0x0
    0x9a 0x0
    0x9b 0x0
    0x9c 0x0
    0x9d 0x0
    0x9e 0x0
    0x9f 0x0
    0xa0 0x0
    0xa1 0x0
    0xa2 0x1
    0xa3 0x0
    0xa4 0x0
    0xa5 0x0
    0xa6 0x0
    0xa7 0x0
    0xa8 0x0
    0xa9 0x0
    0xaa 0x0
    0xab 0x0
    0xac 0x0
    0xad 0x0
    0xae 0x0
    0xaf 0x0
    0xb0 0x5e
    0xb1 0x88
    0xb2 0x0
    0xb3 0x0
    0xb4 0x0
    0xb5 0x0
    0xb6 0x0
    0xb7 0x0
    0xb8 0x0
    0xb9 0x0
    0xba 0x0
    0xbb 0x0
    0xbc 0x0
    0xbd 0x0
    0xbe 0x0
    0xbf 0x0
    0xc0 0x0
    0xc1 0x0
    0xc2 0x0
    0xc3 0x0
    0xc4 0x0
    0xc5 0x0
    0xc6 0x0
    0xc7 0x0
    0xc8 0x0
    0xc9 0x0
    0xca 0x0
    0xcb 0x0
    0xcc 0x0
    0xcd 0x0
    0xce 0x0
    0xcf 0x0
    0xd0 0x0
    0xd1 0x0
    0xd2 0x0
    0xd3 0x0
    0xd4 0x0
    0xd5 0x0
    0xd6 0x0
    0xd7 0x0
    0xd8 0x0
    0xd9 0x0
    0xda 0x0
    0xdb 0x0
    0xdc 0x0
    0xdd 0x0
    0xde 0x0
    0xdf 0x0
    0xe0 0x0
    0xe1 0x0
    0xe2 0x0
    0xe3 0x0
    0xe4 0x0
    0xe5 0x0
    0xe6 0x0
    0xe7 0x0
    0xe8 0x0
    0xe9 0x0
    0xea 0x0
    0xeb 0x0
    0xec 0x0
    0xed 0x0
    0xee 0x0
    0xef 0x0
    0xf0 0x0
    0xf1 0x0
    0xf2 0x0
    0xf3 0x0
    0xf4 0x0
    0xf5 0x0
    0xf6 0x0
    0xf7 0x0
    0xf8 0x0
    0xf9 0x0
    0xfa 0x0
    0xfb 0x0
    0xfc 0x0
    0xfd 0x0
    0xfe 0x0
    0xff 0x1
    [END]
  • Yes ,I can probe the TMDS181 clock output is 150Mhz for 4k@60 in FPGA receive side.
    Info
    HDMI RX SubSystem
    ->HDMI RX Subsystem Cores
    : HDMI RX
    HDMI RX version : 03.00 (0403)
    HDMI RX Mode - DVI
    HDMI RX timing
    No HDMI RX stream
    Link quality
    Link quality channel 0 : bad (65535)
    Link quality channel 1 : bad (65535)
    Link quality channel 2 : bad (65535)
    Audio
    Format : Unknown
    Channels : 2
    ACR CTS : 0
    ACR N : 0
    Infoframe
    RX header: 0
    HDMI PHY
    VPhy version : 02.02 (0000)
    GT status
    RX reference clock frequency: 148498432 Hz
    DRU reference clock frequency: 125000000 Hz
    RX: CPLL
    RX state: ready
    CPLL settings
    M : 1 - N1 : 5 - N2 : 4 - D : 1
    RX MMCM settings
    Mult : 8 - Div : 1 - Clk0Div : 4 - Clk1Div : 8 - Clk2Div : 4
    DRU Settings
    Version : 7
    DRU is disabled
    buffer:5,0040438780
    buffer:5,0040438780
    There are two issues with this design that I saw from the schematic.
    1. TMDS181 supports DC-coupled HDMI, for AC-coupled HDMI, you need to use the DP159.
    2. The TMDS181 DDC snoop mode is not implemented. The DDC snoop mode needs to be implemented so the TMDS_CLOCK_RATIO_STATUS bit switch between HDMI1.4 (Register 0x0B bit 1 = 0) and HDMI 2.0 (Register 0x0B bit 1 = 1). If the snoop mode is not implemented, then you need to manually switch the TMDS_CLOCK_RATIO_STATUS bit between HDMI1.4 and 2.0.
    David
  • Hi David,
    According to your suggestion ,4K@60 can work now.
    Thanks your great support.
  • Hi David
      I have some questions  about TMDS181 with your help3022.I2C register dump.TXT2671.TMDS181-OUTPUT-SCH.pdf
    Using TMDS181RGZT and TPD12S016RKTR to build the HDMI signal channel between FPGA and display (FPGA is the sending end and the display is the receiving end).
    The current problem is: HDMI don't output to 4K or 1080P via i2c mode ,but HDMI signal can display via pin strap mode.
    Do you have any suggestion why TMDS181 don't have output via I2C mode?
    Please see my response to your question in this ticket:
    David
