Data sheet suggests 4.7uF on SDI_IO±, IN0±, and OUT0±. I am wondering what the minimum acceptable value is? (What drives this value?)
...would a 2.2uF X7S 10% make the cut?
Thank you in advance
Iain
Iain
Hi lian,
Why do you want to make this change? I say this since most of the device validation/characterization used 4.7uF AC coupling Cap. I believe there are 0402 form factor 4.7uF Cap available and i thought maybe this is the only reason you may want to make this change.
Regards,, Nasser
Hello Nasser,
Thank you for your response :)
I don't want to change it, I just require a 125C part X7S... worst case I can go with a 105C X6S, yet that will have +/-22% change over temperature. (This a -40 to 85C design)
So, to start, would a +/-22% change away from 4.7uF be significant?
Thank you in advance,
Iain
