Other Parts Discussed in Thread: DP83869
Hi.
We used DP83869 as a 1000M media converter to connect two devices that are far away. And we need synchronize local reference clock to peer side. So we need get the receiving clock, which is recovered from the SGMII stream, to phase-lock to local reference clock.
I knew that CLK_OUT pin can output internal clock that for copper side by setting register 0x170 to proper value. But there's no option to output SGMII port clock. So,
Can DP83869 output clock recovered from SGMII port in media converter mode? How to set register values if can?
Thanks.
