dear Sir
The current design has images and pictures, but the screen has the phenomenon of blurring. Can you help me check the design drawing?
dear Sir
Hi Chang,
Are you seeing any errors on the deserializer? First select the RX port in reg 0x4C, then read the registers below:
Register |
Types of Errors |
Comments |
0x4D |
Status |
0x4D[5]: indicates CRC (BC) error detected 0x4D[2]: indicates parity (FC) error detected 0x4D[0]: indicates whether there's lock |
0x4E |
Status |
0x4E[5]: indicates encoder error detected 0x4E[4]: indicates buffer error detected 0x4E[3]: indicates CSI error detected |
0x56,0x55 |
Parity |
0x56: upper 8 bits of parity error count 0x55: lower 8 bits of parity error count |
0x7A |
CSI Error |
indicates various CSI errors |
0x7B |
CSI Error |
indicates number of CSI packets with errors |
I would also suggest reading reg 0x35 for CSI port PASS.
Jiashow
Hi Chang,
If there's no issues indicated from these registers, then the issue is most likely the configuration of the SoC.
Jiashow
