TPS25750EVM: How does BQ25731 terminate charging when the external battery is used?
Guru 29690 points
Part Number: TPS25750EVM
Other Parts Discussed in Thread: BQ25731, TPS25750, , USB-PD-CHG-EVM-01
Hi Team,
I believe an external battery can be charged with TPS25750EVM (TPS25750+BQ25731).
How does BQ25731 that is mounted on TPS25750EVM terminate charging when the external battery is used?
I assume using Application Configuration Tool (GUI) for TPS25750 to manage the BQ25731.
I believe BQ25731 should be terminate charging by host control originally however BQ25731 is managed by TPS25750.
I couldn't catch how BQ25731 terminates charging the battery.
I would also like to know the value of termination current in this case.
Yaita
