Part Number: UCC256403
Other Parts Discussed in Thread: UCC28950-Q1, , UCC28950
Hi team,
Continuing the previous discussion.
I found that it is loop oscillation. So, I tried to validate the converter in "open Loop" (EA+ voltage is given from VREF through resistor divider). Even in open loop also the same oscillation exists. That is what i mentioned in the previous query.
Can you able to help me to figure out why this oscillation occurs in open loop itself. (when EA+ voltage is 1.3V)
But I tried to change the peak current mode control to Voltage mode control.
In Voltage control mode the sub harmonic oscillations is not present.
It seems like the controller itself oscillates in peak current control mode when the EA+ voltage is 1.3V.
