Hi Team:
Could you help to check the ISOW7841's distance between the two red lines:
Hi Derek,
I don't have exact measured value, but the distance marked should be lower than 1.5mm.
And why is this data required? any specific reason?
Tejas
Hi Derek,
Sorry for taking long time to reply,
I checked this with our package team and according to package design the distance between two red lines would be 1.4 + .125mm = 1.525mm. However, the creepage (Shortest terminal-to-terminal distance across the
package surface/ Air) will be >8mm with HV / ISOLATION land pattern.
Tejas
