Could you please tell me the handling for the pins of ISODE and PV as follows ?
Can the pins of ISODE and PV be kept floating ?
I found in the data sheet that PV pin has a 50-kΩ pull-up resistor and ISODE pin is output.
Kato
Kato
Hi Kato-san,
Since ISODE is an output pin, floating this pin has no impact on device function and since PV input pin has internal 50kΩ pull-up resistor, floating the pin or making it HIGH will enable the device allowing it to operate normal. Hence, you can either make the pin HIGH or leave it floating. Thanks.
Koteshwar Rao
Hi Koteshwar-san,
Thank you for your quick response.
I understood.
Kato
