Other Parts Discussed in Thread: SN6505B, SN6501
Using ISOW7840 with LMV7235M7 comparators on isolated side. The comparators sometimes draw extra current at power-up (latch-up?) causing ISOW7840 to go into current limit. If sufficient current is applied (from additional bench supply), power comes up and stays up after extra supply removed. I've got 2 of the ISOW7840's and shorting their power outputs together to put them in parallel seems to provide adequate current to power up OK. Does placing outputs in parallel cause problems?
