Part Number: ISO7741
I have a customer asking for some qualification information; we have been using the qualification summary page on ti.com, but there are some points I need to confirm.
The Temperature Cycle lists the following.
Stress
Reference
Min Lot Qty
Sample Size / Lot
Condition
Duration
Result
| TC | JESD22-A104 | 3 | 25 | Temperature Cycle -65/150C | 500 Cycles | PASS |
Is my understanding correct?
- -65C/150C is criteria "C" in the JESD22-A104 standard, which means typically 2 cycles per hour. Was this device qualified with 2 cycles per hour? (roughly 30 mins per cycle)
- What test chamber was used? Or, what medium was used? (I assume some gaseous medium, not liquid - specifics not needed)
The Thermal Shock test falls under JESD22-A106B, and has a much faster temperature ramp. To achieve this, liquid chambers are often used. This device has not been qualified for "Thermal Shock" (JESD22-A106B), it has only been qualified for "Temperature Cycling" (JESD22-A104) - yes?
Darren
