I am working on porting MIPI DSI LCD panel (Video mode) with Pandaboard ES Rev B3 , os is android 4.3 with kernel version 3.2.0
My panel spec is LCD size 320x480, HSA = 4 , HFP=10 ,HBP=3, VSA = 2 , VFP=43 ,VBP=2 , Frame rate = 60.03Hz
The current situation : When source code is executing "taal_power_on function" . It will send "0x11"(sleep out) to slave , but having DSI error.
Please tell me which reg setting or coding is not correct and tell me how to trouble shooting.
terminal console :
[ 4.669158] clock: disabling unused clocks to save power
[ 4.681823] omapfb omapfb: failed to apply dispc config
[ 4.692749] omapfb omapfb: failed to apply dispc config
[ 4.703674] omapfb omapfb: failed to apply dispc config
[ 4.710632] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.722747] mmc1: new SDIO card at address 0001
[ 4.822448] omapdss DSI error: DSI CIO error, cio irqstatus 2
[ 4.828582] omapdss DSI error: rx fifo not empty after write, dumping data:
[ 4.835906] omapdss DSI error: rawval 0x000000
[ 4.835906] omapdss DSI error: unknown datatype 0x00
[ 4.845977] omapdss DSI error: dsi_vc_dcs_write(ch 0, cmd 0x11, len 1) failed
[ 4.845977] cmd sleep out implement
[ 4.845977] taal display0: error while enabling panel, issuing HW reset
[ 4.960174] omapfb omapfb: Failed to enable display 'lcd'
[ 4.960174] omapfb omapfb: failed to initialize default display
[ 4.972106] omapfb omapfb: failed to setup omapfb
[ 4.977050] omapfb: probe of omapfb failed with error -5
And my modified program as below:
static struct panel_config panel_configs[] = {
.name = "taal",
// .type = PANEL_TAAL,
.type = 0,
.timings = {
.x_res = 320,
.y_res = 480,
.pixel_clock = 10656,
.hsw=4,
.hfp=10,
.hbp=3,
.vsw=2,
.vfp=43,
.vbp=2,
.sleep = {
.sleep_in = 5,
.sleep_out = 5,
.hw_reset = 100,
.enable_te = 100, /* possible panel bug */
.reset_sequence = {
.high = 10,
.low = 10,
// printk("I called panel_config function");
static struct omap_dss_device sdp4430_lcd_device = {
.name = "lcd",
.driver_name = "taal",
.type = OMAP_DISPLAY_TYPE_DSI,
.data = &dsi1_panel,
.phy.dsi = {
.type=OMAP_DSS_DSI_TYPE_VIDEO_MODE,
.clk_lane = 1,
.clk_pol = 0,
.data1_lane = 2,
.data1_pol = 0,
.module = 0,
.clocks = {
.dispc = {
.channel = {
/* Logic Clock = 144M Hz*/ //144000000
.lck_div = 1,
/* Pixel Clock = 34.56 MHz */
.pck_div = 16,
.lcd_clk_src = OMAP_DSS_CLK_SRC_DSI_PLL_HSDIV_DISPC,
// .dispc_fclk_src = OMAP_DSS_CLK_SRC_FCK,
.dispc_fclk_src = OMAP_DSS_CLK_SRC_DSI_PLL_HSDIV_DISPC,
.dsi = {
.regn = 25, /* Fint = 2.4 MHz */
.regm = 111, /* DDR Clock = 576 MHz One Lane = 288M Hz*/
.regm_dispc = 2, /* PLL1_CLK1 = 144 MHz */
.regm_dsi = 2, /* PLL1_CLK2 = 144 MHz */
.lp_clk_div = 9, /* LP Clock = 10.29 MHz */
// .offset_ddr_clk = 0,
.dsi_fclk_src = OMAP_DSS_CLK_SRC_DSI_PLL_HSDIV_DSI, //170.7M Hz
.channel = OMAP_DSS_CHANNEL_LCD,
And Debug Message as below :
- DSS -
dpll4_ck 1536000000
DSS_FCK (DSS_FCLK) = 1536000000 / 9 = 170666666
- DISPC -
dispc fclk source = DSS_FCK (DSS_FCLK)
fck 170666666
- DISPC-CORE-CLK -
lck 170666666 lck div 1
- LCD1 -
lcd1_clk source = DSI_PLL_HSDIV_DISPC (PLL1_CLK1)
lck 170496000 lck div 1
pck 10656000 pck div 16
- LCD2 -
lcd2_clk source = DSS_FCK (DSS_FCLK)
lck 42666666 lck div 4
pck 42666666 pck div 1
- DSI1 PLL -
dsi pll source = dss_sys_clk
Fint 1536000 regn 25
CLKIN4DDR 340992000 regm 111
DSS_FCK (DSS_FCLK) 170496000 regm_dispc 2 (off)
DSS_FCK (DSS_FCLK) 170496000 regm_dsi 2 (off)
- DSI1 -
dsi fclk source = DSS_FCK (DSS_FCLK)
DSI_FCLK 170666666
DDR_CLK 85248000
TxByteClkHS 21312000
LP_CLK 9472000
DISPC_REVISION 00000040
DISPC_SYSCONFIG 00002015
DISPC_SYSSTATUS 00000001
DISPC_IRQSTATUS 00000000
DISPC_IRQENABLE 0012d640
DISPC_CONTROL 00018308
DISPC_CONFIG 00020004
DISPC_CAPABLE 00000000
DISPC_DEFAULT_COLOR(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DEFAULT_COLOR(OMAP_DSS_CHANNEL_DIGIT) 00000000
DISPC_TRANS_COLOR(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_TRANS_COLOR(OMAP_DSS_CHANNEL_DIGIT) 00000000
DISPC_LINE_STATUS 00000000
DISPC_LINE_NUMBER 00000000
DISPC_TIMING_H(OMAP_DSS_CHANNEL_LCD) 00200903
DISPC_TIMING_V(OMAP_DSS_CHANNEL_LCD) 00202b01
DISPC_POL_FREQ(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DIVISORo(OMAP_DSS_CHANNEL_LCD) 00010010
DISPC_GLOBAL_ALPHA ffffffff
DISPC_SIZE_MGR(OMAP_DSS_CHANNEL_DIGIT) 00000000
DISPC_SIZE_MGR(OMAP_DSS_CHANNEL_LCD) 01df013f
DISPC_CONTROL2 00000000
DISPC_CONFIG2 00000000
DISPC_DEFAULT_COLOR(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_TRANS_COLOR(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_TIMING_H(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_TIMING_V(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_POL_FREQ(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_DIVISORo(OMAP_DSS_CHANNEL_LCD2) 00040001
DISPC_SIZE_MGR(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_OVL_BA0(OMAP_DSS_GFX) 00000000
DISPC_OVL_BA1(OMAP_DSS_GFX) 00000000
DISPC_OVL_POSITION(OMAP_DSS_GFX) 00000000
DISPC_OVL_SIZE(OMAP_DSS_GFX) 00000000
DISPC_OVL_ATTRIBUTES(OMAP_DSS_GFX) 000000a0
DISPC_OVL_FIFO_THRESHOLD(OMAP_DSS_GFX) 04ff04f8
DISPC_OVL_FIFO_SIZE_STATUS(OMAP_DSS_GFX) 00000500
DISPC_OVL_ROW_INC(OMAP_DSS_GFX) 00000001
DISPC_OVL_PIXEL_INC(OMAP_DSS_GFX) 00000001
DISPC_OVL_WINDOW_SKIP(OMAP_DSS_GFX) 00000000
DISPC_OVL_TABLE_BA(OMAP_DSS_GFX) 00000000
DISPC_DATA_CYCLE1(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DATA_CYCLE2(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DATA_CYCLE3(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_CPR_COEF_R(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_CPR_COEF_G(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_CPR_COEF_B(OMAP_DSS_CHANNEL_LCD) 00000000
DISPC_DATA_CYCLE1(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_DATA_CYCLE2(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_DATA_CYCLE3(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_CPR_COEF_R(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_CPR_COEF_G(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_CPR_COEF_B(OMAP_DSS_CHANNEL_LCD2) 00000000
DISPC_OVL_PRELOAD(OMAP_DSS_GFX) 00000100
DISPC_OVL_BA0(o) 00000000
DISPC_OVL_BA1(o) 00000000
DISPC_OVL_POSITION(o) 00000000
DISPC_OVL_SIZE(o) 00000000
DISPC_OVL_ATTRIBUTES(o) 00008400
DISPC_OVL_FIFO_THRESHOLD(o) 07ff07f8
DISPC_OVL_FIFO_SIZE_STATUS(o) 00000800
DISPC_OVL_ROW_INC(o) 00000001
DISPC_OVL_PIXEL_INC(o) 00000001
DISPC_OVL_FIR(o) 04000400
DISPC_OVL_PICTURE_SIZE(o) 00000000
DISPC_OVL_ACCU0(o) 00000000
DISPC_OVL_ACCU1(o) 00000000
DISPC_OVL_FIR_COEF_H(o, i) 00000000
DISPC_OVL_FIR_COEF_HV(o, i) 00000000
DISPC_OVL_CONV_COEF(o, i) 00000000
DISPC_OVL_FIR_COEF_V(o, i) 00000000
DISPC_OVL_BA0_UV(o) 00000000
DISPC_OVL_BA1_UV(o) 00000000
DISPC_OVL_FIR2(o) 04000400
DISPC_OVL_ACCU2_0(o) 00000000
DISPC_OVL_ACCU2_1(o) 00000000
DISPC_OVL_FIR_COEF_H2(o, i) 00000000
DISPC_OVL_FIR_COEF_HV2(o, i) 00000000
DISPC_OVL_FIR_COEF_V2(o, i) 00000000
DISPC_OVL_ATTRIBUTES2(o) 00000000
DISPC_OVL_PRELOAD(o) 00000100
DSI_REVISION 00000030
DSI_SYSCONFIG 00000015
DSI_SYSSTATUS 00000001
DSI_IRQSTATUS 00000100
DSI_IRQENABLE 0015c000
DSI_CTRL 00faea98
DSI_COMPLEXIO_CFG1 60000021
DSI_COMPLEXIO_IRQ_STATUS 00000000
DSI_COMPLEXIO_IRQ_ENABLE 3ff07fff
DSI_CLK_CTRL 00344009
DSI_TIMING1 ffff7fff
DSI_TIMING2 ffff7fff
DSI_VM_TIMING1 02007001
DSI_VM_TIMING2 04022b02
DSI_VM_TIMING3 00fc01e0
DSI_CLK_TIMING 00000e0f
DSI_TX_FIFO_VC_SIZE 13121110
DSI_RX_FIFO_VC_SIZE 13121110
DSI_COMPLEXIO_CFG2 00000000
DSI_RX_FIFO_VC_FULLNESS 00000000
DSI_VM_TIMING4 00487296
DSI_TX_FIFO_VC_EMPTINESS 00000000
DSI_VM_TIMING5 0082df3b
DSI_VM_TIMING6 7a6731d1
DSI_VM_TIMING7 0012000f
DSI_STOPCLK_TIMING 00000080
DSI_VC_CTRL(0) 20800580
DSI_VC_TE(0) 00000000
DSI_VC_LONG_PACKET_HEADER(0) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(0) 00000000
DSI_VC_SHORT_PACKET_HEADER(0) 00000000
DSI_VC_IRQSTATUS(0) 00000000
DSI_VC_IRQENABLE(0) 000000db
DSI_VC_CTRL(1) 20800d80
DSI_VC_TE(1) 00000000
DSI_VC_LONG_PACKET_HEADER(1) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(1) 00000000
DSI_VC_SHORT_PACKET_HEADER(1) 00000000
DSI_VC_IRQSTATUS(1) 00000000
DSI_VC_IRQENABLE(1) 000000db
DSI_VC_CTRL(2) 20800d80
DSI_VC_TE(2) 00000000
DSI_VC_LONG_PACKET_HEADER(2) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(2) 00000000
DSI_VC_SHORT_PACKET_HEADER(2) 00000000
DSI_VC_IRQSTATUS(2) 00000000
DSI_VC_IRQENABLE(2) 000000db
DSI_VC_CTRL(3) 20800d80
DSI_VC_TE(3) 00000000
DSI_VC_LONG_PACKET_HEADER(3) 00000000
DSI_VC_LONG_PACKET_PAYLOAD(3) 00000000
DSI_VC_SHORT_PACKET_HEADER(3) 00000000
DSI_VC_IRQSTATUS(3) 00000000
DSI_VC_IRQENABLE(3) 000000db
DSI_DSIPHY_CFG0 08110b0d
DSI_DSIPHY_CFG1 42030817
DSI_DSIPHY_CFG2 b8000006
DSI_DSIPHY_CFG5 60000000
DSI_PLL_CONTROL 00000000
DSI_PLL_STATUS 000001c9
DSI_PLL_GO 00000000
DSI_PLL_CONFIGURATION1 0420de31
DSI_PLL_CONFIGURATION2 00656008
DSS_REVISION 00000040
DSS_SYSCONFIG 00000000
DSS_SYSSTATUS 00000001
DSS_CONTROL 00000001
THX
Please dont open duplicate threads to your original queries, and follow the official forum rules.
Please click the Verify Answer button on this post if it answers your question.
Be sure to read the OMAP4 and OMAP5 Forum Guidelines and FAQ
