The TI E2E™ design support forums will undergo maintenance from Sept. 28 to Oct. 2. If you need design support during this time, contact your TI representative or open a new support request with our customer support center.
SN74LVC16T245-EP: CLVC16T245MDGGREP Data Rate
Part Number: SN74LVC16T245-EP
I want to know the maximum data rate supported by CLVC16T245MDGGREP IC.
Thanks in Advance
Ranjini
  • Hello Ranjini,
    The maximum data rate supported by the part is 200 MHz.
    Kind regards,
    Reed Smoot
    I would like to know the max data rate for level shifting from 1.8V to 3.3V (A to B), 3.3V to 1.8V (B to A).
     Thanks & Regards,
    Ranjini.R
  • Hi Ranjini,
    Since the maximum frequency of 200 MHz is correlated to a voltage translation of 3.3 V to 5 V, theoretically a reduction to half of that voltage would correlate to half of that frequency.
    However, to accurately determine the maximum data rate for 1.8 V to 3.3 V and vice versa, I recommend testing this part on an EVM with the specific output load of your application. This will be the only way to realistically verify the maximum data rate for your system.
    Sincerely,
    Reed Smoot
