Part Number: SN74AVC8T245
Other Parts Discussed in Thread: SN74AXC8T245
I am plan to use SN74AVC8T245 to translate USB signal by ULPI interface which the data rate is 60Mbps per channel.
The usb signal is bi-directional, so I want to know how long will it be active if I switch the direction from A to B to B to A.
I checked with USB PROTOCOL, the switching time should within 16ns, I am not sure whether this chip can meet the requirement, please help with confirm.
And also, I saw there is a layout requirement that the PCB trace should be short with this chip, do you have more specific requirement of this?
Because in our path, there will be one 1m cable, two 10cm cable and 20inch pcb trace, do we have any risk of this path?
Qiang
