We are now defining the diagnosis of output driven by this latch IC (SN74LVC2G74QDCURQ1).
Can I check the possibility of the output of this IC (pin5) stuck at high ?
Was there any failure return reported due to pin5 stuck at high ?
Hi Andy,
Can you give some more information into this issue?
What is the exact problem and can you send some scope shots of the issue to us?
Anything can cause a device to be stuck in high state, you will have to be more specific so we can help solve this.
Hi - Per the customer there is no exact problem (IC pin5 stuck at high) in our application so far.
But we would like to check possibility from IC point of view. Appreciate your insights if any, thanks.
Hi Andy,
I'm not sure what I can do to help you with this.
The best thing I can do is just to refer you to the truth table in the datasheet:
