Will SN74LV8153 allow me to change each relays set without effecting the other ones? For example I want a relay to turn on the ignition to an engine. Then one will turn on to turn the starter on the same engine. Once the engine has started I want to turn off the starter relay, but keep the ignition one on. If this part will not work do you have one that you would recommend, or a recommendation on a part style I should try. Thank you.. David P.
