The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
SN74AHCT123A and SN74LS221 - some questions
Other Parts Discussed in Thread: SN74LS221, SN74AHCT123A, SN74AHC123A
Hi all
Would you mind if we ask SN74AHCT123A and SN74LS221?
<Question1>
How much is the minimum wide pulse?
Using each devices and Cext/Rext, our customer would like to calculate wide pulse.
Could you let us know the calculation formula?
<Question2>
On the datasheet SN74LS221 P2 ,  it shows Cext=0.
What does Cext=0 mean? We guess that it means open.
Is our recognition correct?
Kind regards,
Hirotaka Matsumoto
  • Hello Hirotaka Matsumoto,
    For SN74AHC123A:
    On page 4 of the datasheet, the minimum pulse duration is listed as 5ns.
    The output pulse duration can be calculated from this equation:
    tw = K x Rext x Cext,
    K is a multiplier that depends on the capacitor value. Page 7 of the datasheet explains that K is 1 for any Ct value greater than or equal to 1000pF. For a capacitor value less than 1000pF, I would refer you to figure 9 on page 10 of the datasheet to help gauge the K value. Also, figure 5 of the datasheet shows variation in tw based on varying Rt and Ct values.
    For SN74LS221:
    tw = Cext x Rext x ln(2) ~= 0.7 x Cext x Rext.
    The minimum Rext and Cext values are listed on page 6 of the datasheet. So using those and the equation, the pulse width can be calculated. Figure 6 on page 13. This plot shows output pulse based on resistor and capacitor values. Based off this plot, a 30ns output pulse is achievable using a 4kOhm resistor with a 10pF capacitor.
    To answer your second question, if Cext is left open (Cext = 0) a typical output pulse duration of 30ns can be achieved with a 2kOhm resistor, based off page 2 of the datasheet.
    Hope this answers your questions!
    Joe Stephan
  • Joe san
    Thank you for your reply!
    Ok we got it.
    Kind regards,
    Hirotaka Matsumoto
