Other Parts Discussed in Thread: SN74LVCH16T245
what is maximum data rate one can achieve using SN74LVCH16T245? I want to operate it for logic level 3.3V to 5V conversion. In data sheet tPLH and tPHL are specified as 4.4 ns max that means 225 MHz?
Hello Patil
Using propagation delays is not always the best way to get Fmax. The best way is to use rise and fall times if you have them. These will vary with the output load.
Your calculation in this case is pretty accurate. The Fmax should be about 200Mhz.
