SN74AUP1G79: How to use this part on downclocking application? 5kHz to 2.5kHz.
Part Number: SN74AUP1G79
Other Parts Discussed in Thread: SN74AUP1G80,
Hi Team,
How to use this part on downclocking application. 5kHz to 2.5kHz?
5kHz input to pinD?
How to set CLK signal?
  • Hi Daniel,
    The SN74AUP1G79 is not ideal to use as a clock divider since it does not have an inverted output. I would recommend using the SN74AUP1G80 instead. If you are set on using the 1G79, just add an inverter after Q to get Q\ and use the diagram from the 1G80 datasheet.
    The datasheet includes an application for exactly what you are wanting to do on page 10.
