Part Number: SN74HCT14
Other Parts Discussed in Thread: SN74LVC14A
Hi,Engineer:
Please provide the reliability test report and Failure Mode Effects Analysis(FMEA) report of the following SN74HCT14 device,thanks!
shaocong
Hi,Engineer:
shaocong
Hi Shaocong,
All of the Quality reports for this device can be found at the link below:
Hi,Hubbard:
I can’t find the FMEA document,do you have any?In addition, I would like to ask a question,SN74HCT14 recommended operating VCC Supply voltage 4.5V~5.5V, If I set the VCC supply voltage to 3.3V, what will be the problem and impact?
shaocong
Hi Shaocong,
If you couldn't find the FMEA there, then I don't believe one exists for this device.
It won't be in the recommended operating conditions, it may or may not work. If you want to supply it with 3.3 V, I recommend using another device that isn't TTL compatible like the SN74LVC14A.
Hi,Hubbard:
I did an experiment. If the power supply voltage was set to 3.3V, the input and output signals could be reversed, but I don't know what would happen if the power supply voltage was set to 3.3V for a long time. Have you done any low supply voltage work tests?
shaocong
