Part Number: SN74HC14
Other Parts Discussed in Thread: CD74HC14
Customer is looking for p2p compatible with ON-SEMI device of the MC74HC14ADR2G.
Are there two items suitable?
1. SN74ACT04DR
2. SN74HC14DR
The ACT04 has TTL input thresholds, runs only at 5 V, and does not have Schmitt triggers.
The cross reference tool points to the CD74HC14M96.
Thanks.
There are 38 items suggested after running Cross reference parts for On Semiconductor MC74HC14ADR2G on TI website.
Are all below items able to replace the MC74HC14ADR2G? Thanks.
| CD74HC14M96 | S | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 108,800 | ACTIVE | Compare | Select | ||
| SN74HC14DR | P | Hex Schmitt-Trigger Inverters | 672,825 | ACTIVE | Compare | Select | ||
| CD74HCU04M96E4 | F | High Speed CMOS Logic Hex Inverters | 10,000 | ACTIVE | Compare | Select | ||
| SN74HCU04DR | F | Hex Inverters | 37,029 | ACTIVE | Compare | Select | ||
| SN74HC14DRG3 | F | Hex Schmitt-Trigger Inverters | 3,985 | ACTIVE | Compare | Select | ||
| CD74HCU04M | F | High Speed CMOS Logic Hex Inverters | 5,995 | ACTIVE | Compare | Select | ||
| CD74HC14MTG4 | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 250 | ACTIVE | Compare | Select | ||
| CD74HC14M | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 12,932 | ACTIVE | Compare | Select | ||
| CD74HC14ME4 | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 12,932 | ACTIVE | Compare | Select | ||
| SN74HC04DRG4 | F | Hex Inverters | 2,500 | ACTIVE | Compare | Select | ||
| SN74HC14DRG4 | F | Hex Schmitt-Trigger Inverters | 31,440 | ACTIVE | Compare | Select | ||
| SN74HCU04DT | F | Hex Inverters 14-SOIC -40 to 85 | ACTIVE | Compare | Select | |||
| CD74HC04M | F | High Speed CMOS Logic Hex Inverters | 5,790 | ACTIVE | Compare | Select | ||
| CD74HCU04M96 | F | High Speed CMOS Logic Hex Inverters | 10,000 | ACTIVE | Compare | Select | ||
| SN74HC14QDRG4Q1 | F | Automotive Catalog Hex Schmitt-Trigger Inverters | 4,998 | ACTIVE | Compare | Select | ||
| CD74HC14M96E4 | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 108,800 | ACTIVE | Compare | Select | ||
| CD74HC14MT | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 250 | ACTIVE | Compare | Select | ||
| SN74HC14QDRQ1 | F | Automotive Catalog Hex Schmitt-Trigger Inverters | 33,985 | ACTIVE | Compare | Select | ||
| CD74HC04MT | F | High Speed CMOS Logic Hex Inverters 14-SOIC -55 to 125 | ACTIVE | Compare | Select | |||
| CD74HC14MG4 | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 12,932 | ACTIVE | Compare | Select | ||
| CD74HC04M96E4 | F | High Speed CMOS Logic Hex Inverters | 115,679 | ACTIVE | Compare | Select | ||
| CD74HCU04M96G4 | F | High Speed CMOS Logic Hex Inverters | 10,000 | ACTIVE | Compare | Select | ||
| CD74HC14M96G4 | F | High Speed CMOS Logic Hex Schmitt-Triggered Inverters | 108,800 | ACTIVE | Compare | Select | ||
| SN74HC14D | F | Hex Schmitt-Trigger Inverters | 75,796 | ACTIVE | Compare | Select | ||
| SN74HC04DR | F | Hex Inverters | 135,869 | ACTIVE | Compare | Select | ||
| SN74HC04D | F | Hex Inverters | 24,358 | ACTIVE | Compare | Select | ||
| SN74HC04DT | F | Hex Inverters | 500 | ACTIVE | Compare | Select | ||
| SN74HCU04D | F | Hex Inverters | 13,977 | ACTIVE | Compare | Select | ||
| SN74HC04DRG3 | F | Hex Inverters 14-SOIC -40 to 85 | ACTIVE | Compare | Select | |||
| SN74HC14DTG4 | F | Hex Schmitt-Trigger Inverters | 496 | ACTIVE | Compare | Select | ||
| SN74HC14DT | F | Hex Schmitt-Trigger Inverters | 496 | ACTIVE | Compare | Select | ||
| SN74HC14DG4 | F | Hex Schmitt-Trigger Inverters | 75,796 | ACTIVE | Compare | Select | ||
| SN74HC14DE4 | F | Hex Schmitt-Trigger Inverters | 75,796 | ACTIVE | Compare | Select | ||
| SN74HC14DRE4 | F | Hex Schmitt-Trigger Inverters | 31,440 | ACTIVE | Compare | Select | ||
| SN74HCU04DRG4 | F | Hex Inverters 14-SOIC -40 to 85 | ACTIVE | Compare | Select | |||
| SN74HC04DE4 | F | Hex Inverters | 24,358 | ACTIVE | Compare | Select | ||
| CD74HC04M96 | F | High Speed CMOS Logic Hex Inverters | 115,679 | ACTIVE | Compare | Select | ||
| SN74HC04DRE4 | F | Hex Inverters | 2,500 | ACTIVE | Compare | Select |
