Input impedance of SN74CB3Q330x / TS12A451x
Other Parts Discussed in Thread: SN74CB3Q3306A, SN74CB3Q3305, TS12A4515, TS12A4514
Can you please confirm if INPUT of SN74CB3Q3305 or SN74CB3Q3306A is high Z when,
1) Vcc=0V
2) Vcc=3.3V but OE/=high (disabled)
I see only max Vcc level difference between SN74CB3Q3305 and SN74CB3Q3306A. Is there any other noticeable discrepancies?
Same question for TS12A4514 or TS12A4515. Their IN pin is in high Z when V+ is 0V?
Is there any other noticeable discrepancies between TS12A4514 and TS12A4515?
Thanks in advance for your advice.
Thanks, Gibson
  • The A/B pins of the SN74CB3Q330x are Hi-Z when disabled or powered off.
    The TS12A451x have protection diodes to Vcc, so you must not apply voltages to COM/NO/NC when powered off. (The difference between -4 and -5 is only whether they are normally open or closed.)
  • Thanks for quick answer.
    Thanks, Gibson
  • Please let me have one additional question:
    Do you have measured leakage current value in each cases below? Is the leakage current same at each case?
    1) power off and A/B =3.3V
    2) disabled (OE# =HIGH) and A/B=3.3V
  • Hi Gibson,
    For the TS12A devices, as Clemens mentioned, don't apply 3.3V to the inputs when the supply is < 3.3V. The current will be huge and will damage the device. Otherwise, the leakage current specs are listed on the datasheet and are rather detailed. Do you have a question about one in particular or are you having trouble determining what those values mean?
    For the SN74CB3Q devices, the leakage when the supply is 0V is called "I_off" and is listed as 1uA max on the datasheet. The leakage for when the switch is disabled is called "I_OZ" and is also 1uA max on the datasheet.
