SN74AUP1G74: Thermal information
Part Number: SN74AUP1G74
Hi Sirs,
Sorry to bother you.
We would like to know
1. SN74AUP1G74DQER Rjc /Rjb /TC
2. SN74LVC2G125DCUR TC
Could you help it?
Thanks!!
    Today is a TI holiday. We will submit this thermal request when we return to the office. Becuase of the holidays, I would expect the results to take 3 to 4 weeks return after that.
  • Hi Shu,
    SN74LVC2G125DCUR thermal values below in oC/W
    Result- Theta JA-High K (standard datasheet value)
    190.1
    Result-Theta JC, top (standard datasheet value)
    69.8
    Result-Theta JB (standard datasheet value)
    38.9
    Result- Psi JT (standard datasheet value)
    5.6
    Result- Psi JB (standard datasheet value)
    68.5
  • Hi Sirs,
    Thanks for your reply.
    Actually we would like to know
    But looks you only share SN74LVC2G125DCUR others thermal values.
    So, could you help us to check again?
    Thanks!!
  • Hi Shu-cheng,
    The AUP1G74 thermal is not ready yet, hence I shared SN74LVC2g125DCU device thermals which were ready.
    TC stands for case temperature? We only specify the Tjmax (abs max junction temp) at 150C, beyond which there could be reliability issues.
  • Hi Shu-Cheng,
    sn74AUP1G74DQE Thermal values below in oC/W
    271.3
    145.6
    162.5
    11.7
    161.9
    Result-Theta JC, bottom (standard datasheet value)
    n/a
