Other Parts Discussed in Thread: TINA-TI
Hi all,
I would like TINA-TI model for SN74HCS72-Q1 to simulate /PRE pin behavior. Can you make this?
RYO
Hi all,
RYO
Hi RYO,
I can make this model for you. Please allow me a week to make this.
Thanks!
-Karan
I have created the following model. I have done some tests with it but if you see some use cases where it doesn't work please let me know.
Thanks!
-Karan
Hi Karan,
FYI: I'm observing the following odd behavior with this SPICE model from https://www.ti.com/lit/zip/sclm299...
If I use separate supplies to tie the CLR and PRE pins high, the model works fine.
However, if I connect the PRE and CLK pins to the same supply or tied them to VCC the simulation does not work. i.e. I don't see any activity on Q or Q_N.
Hi Chris,
Yes, our D-Flip Flop PSpice models are really finicky. I'm afraid there's not really much I can do to fix this issue.
Thanks!
Chad Crosby
