SN74LVC1G06-EP: Open Drain: Discrepancy between Logic Table and Description
Part Number: SN74LVC1G06-EP
Other Parts Discussed in Thread: SN74LVC1G06
Hello
I wish to use SN74LVC1G06-EP for its Open-Drain output. In the description and elsewhere in the datasheet there are numerous mention of the same. Even in the switching diagrams, it says t-plz  and t-pzl.
But in the Function Table given on page# 2 of the datasheet, the output is either L or H whereas it should be L or Z.
Can you clarify this, please? Or is it me who is missing something here.
Atin
  • The same "H" entries can be found in the datasheets of other open-drain devices. Apparently, this table assumes that you're using a pull-up resistor.
    In any case, this device definitely has an open-drain output.
  • Hi Atin,
    In our newer datasheets we do update this to differentiate "Z" and "H," but we still have a lot of these older datasheets on the web.
    The datasheet correctly has  VOL but no VOH specification, which is indicative of a device that cannot drive the output high.
    Clemens is correct - the output of the device is open-drain. When an open-drain device is outputting a functional 'high' it actually is just in high-impedance mode.
  • Hi Emrys
    The new datasheet containing the correct table is for SN74LVC1G06, but it is still wrong (or confusing) in the SN74LVC1G06-EP datasheet. I always get the datasheet from the official source.
    And since I only looked at the EP datasheet it confused me a bit even after everything else in the datasheet suggesting it was Open Drain output.
    Thanks for your time and reply.
    Atin
  • Thanks Clemens, every part of the datasheet was telling me it is Open Drain except for that one table.
    So now I know for sure.
    Atin
