I am working on a design with this PLL chip, and I don't know what I am expected to hook up Pin 15 to. It appears to be an internal zener diode and the datasheet says it's to assist in supply regulation.
What should I connect pin 15 to?
Hey Brian, welcome to the forums!
I honestly couldn't tell you why that Zener diode was included with these devices. I've never seen it actually used in a design.
I'd recommend to just terminate that pin to ground or leave it floating -- either way, it won't have an impact on performance of the device.
Right. I won't be connecting it, but I still don't quite understand another related element of the design.
If the Zener Diode is tied to Vss, that suggests that Vss would have to be above ground potential to drive the zener, or below. How does the rest of the circuit operate if Vss is being pulled to to a potential that is > or < ground?
