Hi Team,
This is customer request can you please advise:
SN74LVCH16T245-EP level translator product of TI is being used in a design.
During tests, we detected a problem with this translator. VCCA and VCCB supplies are 3.3V and 5V respectively. Firstly, 5V supply is opened. ~30ms later, 3.3V supply is opened. At the point of 3.3V supply activation, a pulse is observed at the output pins of the translator. Duration of pulse is 150us, along this time the signal is high, then it falls to low. OE pin is grounded. DIR pin is pulled up, so the direction is from A to B.
What is the reason of this problem? Could you suggest any solution?
Thanks in advance
Best Regards
Furkan Sefiloglu
