Other Parts Discussed in Thread: SN74AUC1G125, SN74LVC3G34
Hi Team,
I would like to confirm if our SN74LVC1G125 can work at 100MHz at 1.8V?
Thank you and looking forward for your response.
Maynard
Hi Team,
Maynard
How to Select Little Logic says 80 Mbps (40 MHz).
Hi Emrys,
Thank you for the information. The customer asked if we have any buffers with output drive at 1.8V greater than 12 mA?
Again thank you and looking forward for your kind response.
Maynard
Hi Maynard,
Most logic devices will drive far more current than the given datasheet specification, however we would no longer guarantee the output voltage at the higher current values.
If the customer needs a guaranteed V_OH or V_OL while producing 12 mA at 1.8V, the best solution is to parallel multiple channels of a single device. The LVC logic family is probably the best choice for this due to its simplicity and strong output drivers.
The SN74LVC3G34 has guaranteed VOH and VOL values at 4mA, so all 3 channels could be paralleled to produce a guaranteed 12mA output with the same VOH and VOL values.
I should note that I've never seen a system where that would be required. The output strength of LVC is extremely strong and should have no problems driving any signal line without paralleling the channels.
One solution could be to use the 3 channel device and add 0 ohm resistors to the outputs so that 1, 2, or 3 parallel channels could be used in the final design -- then the customer could easily modify the BOM of their system to get the exact drive strength desired.
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
