Other Parts Discussed in Thread: CC1120, WMBUS
I would like to know how to fix the register settings with using SmartRF studio.
In my customer's system, they would like to configure 200kbps BW. However, if only the BW is changed, RSSI becomes worse.
I selected the sample of '868MHz, 1.2kbps, 2FSK, BW=25kHz' in the menu and change the frequency is 915MHz. In this case, there is no issue on RSSI measurement.
However, if the BW is changed to 200kHz, RSSI becomes worse suddenly. There is no Tx board in the test room. The result is attached below.
Is there any configuration needed to change BW?
Masa
