Hi All,
I am working on WSN based project using Thingsquar mist stack on cc2538dk using CCSV5 on Ubuntu 12.04.
While building blinker example I have got below error.Please lewt me know what was the cause for that.
**** Build of configuration Debug for project mist_1 ****
/opt/ti/ccsv5/utils/bin/gmake -k all
Building file: ../blink.c
Invoking: ARM Compiler
"/opt/ti/ccsv5/tools/compiler/arm_5.0.4/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me -g --include_path="/opt/ti/ccsv5/tools/compiler/arm_5.0.4/include" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/core/sys" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/core" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/core/net" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/cpu/cc2538" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/cpu/arm/common/usb" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/cpu/arm/common/usb" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/platform/cc2538dk/dev" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/platform/cc2538dk" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/platform/mist-cc2538dk" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/platform/cc2538dk" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/dev" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/aes" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/drowsie" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/ip64" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/ip64-addr" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/mdns" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/simple-rpl" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/tcp-socket" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/udp-socket" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/websocket" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/mist-conf" --gcc --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="blink.pp" "../blink.c"
Finished building: ../blink.c
Building file: ../contiki-mist-cc2538dk-main.c
"/opt/ti/ccsv5/tools/compiler/arm_5.0.4/bin/armcl" -mv7M3 --code_state=16 --abi=eabi -me -g --include_path="/opt/ti/ccsv5/tools/compiler/arm_5.0.4/include" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/core/sys" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/core" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/core/net" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/cpu/cc2538" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/cpu/arm/common/usb" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/cpu/arm/common/usb" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/platform/cc2538dk/dev" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/platform/cc2538dk" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/platform/mist-cc2538dk" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/contiki/platform/cc2538dk" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/dev" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/aes" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/drowsie" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/ip64" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/ip64-addr" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/mdns" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/simple-rpl" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/tcp-socket" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/udp-socket" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/websocket" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps" --include_path="/home/preva-powerwise/Documents/PowerWISE/MIST/thingsquare-mist-1.0.1/apps/mist-conf" --gcc --diag_warning=225 --display_error_number --diag_wrap=off --preproc_with_compile --preproc_dependency="contiki-mist-cc2538dk-main.pp" "../contiki-mist-cc2538dk-main.c"
"../contiki-mist-cc2538dk-main.c", line 143: warning #225-D: function declared implicitly
1 Assembly Error, No Assembly Warnings
>> Compilation failure
"../contiki-mist-cc2538dk-main.c", line 210: warning #1181-D: #warning directive: Using default AES key "thingsquare mist", change it in project-conf.h like this:
"../contiki-mist-cc2538dk-main.c", line 211: warning #1181-D: #warning directive: #define NETSTACK_AES_KEY {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15}
"../contiki-mist-cc2538dk-main.c", line 216: warning #225-D: function declared implicitly
"/tmp/02375BykbUm", ERROR! at line 629: [E0300] Symbol nop has already been
defined
.dwpsn file "../contiki-mist-cc2538dk-main.c",line 99,column 29,is_stmt,isa 1
Errors in Source - Assembler Aborted
gmake: *** [contiki-mist-cc2538dk-main.obj] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
Thanks in advance,
jagas
