TMS570LC4357: UART bootloader in TMDX570LC43HDK
Part Number: TMS570LC4357
Other Parts Discussed in Thread: TMDX570LC43HDK, HALCOGEN, , TMS570LS1224
Hi Team,
UART Bootloader for Hercules is TMS570LS12x MCU  need to support for TMDX570LC43HDK
http://www.ti.com/lit/zip/spna192
How to configure the Hercules TMDX570LC43HDK  in HALCoGen   for UART bootloader and what all the modification need to do in code?
  • Thanks, but unfortunately it still doesn't work.
    1. Build and push Bootloader
    2. Upload blinky_APP20020
    3. Run application
    4. Bootloader hangs when it tries to run application
    If you reset the board, the terminal output shows only -
    If I push the blinky_APP20020 firmware to the HDK by itself, it runs... until you hit the reset button, then it no longer runs.
    Are we running a different HDK than the one you are having success with?
  • Hi Chris Dickerson,
    Yes, I too face the same issue in my bootloader that download, run application and upload Its getting hang some times.
    I still confused on the memory side.
    Bootloader
    and in application LED Blinking.
    How we can change the stack and RAM memory?
    Please confirm me in the memory section.
  • We got it to work.
    In the application (blinky) link file, memory section:
        VECTORS (X)      : origin=0x00020020 length=0x00000020 fill=0xFFFFFFFF
        FLASH_CODE  (RX) : origin=0x00020040 length=0x8000 - 0x40  fill=0xFFFFFFFF  /*sector 4/5*/
        FLASH0  (RX)     : origin=0x00028000 length=0x00200000 - 0x28000
        STACKS  (RW)     : origin=0x08000000 length=0x00001500
        RAM     (RWX)    : origin=0x08001500 length=0x0007EB00
    In the bootloader, make sure in bl_config.h the APP_START_ADDRESS and APP_STATUS_ADDRESS are in the same range (NOT 0x00200020).
  • Hi QJ Wang,
    In application link file
    MEMORY
    /* USER CODE BEGIN (2) */
    #if 0
    /* USER CODE END */
    // VECTORS (X) : origin=0x00000000 length=0x00000020
    // FLASH0 (RX) : origin=0x00000020 length=0x001FFFE0
    // FLASH1 (RX) : origin=0x00200000 length=0x00200000
    // STACKS (RW) : origin=0x08000000 length=0x00001500
    // RAM (RW) : origin=0x08001500 length=0x0007EB00
    /* USER CODE BEGIN (3) */
    #endif
    SECTIONS
    /* USER CODE BEGIN (5) */
    .intvecs : {} > VECTORS
    #if 0
    /* USER CODE END */
    .text align(32) : {} > FLASH0 | FLASH1
    .const align(32) : {} > FLASH0 | FLASH1
    .cinit align(32) : {} > FLASH0 | FLASH1
    .pinit align(32) : {} > FLASH0 | FLASH1
    .bss : {} > RAM
    .data : {} > RAM
    .sysmem : {} > RAM
    /* USER CODE BEGIN (6) */
    #endif
    .text align(32) : {} > FLASH_CODE
    .const align(32) : {} > FLASH_CODE
    .cinit align(32) : {} > FLASH_CODE
    .pinit align(32) : {} > FLASH_CODE
    .bss : {} > RAM
    .data : {} > RAM
    .sysmem : {} > RAM
    /* USER CODE END */
    Changed in bl_config.h
    #define APP_START_ADDRESS 0x00020040
    #define APP_STATUS_ADDRESS 0x00020020
    Now, It is not working still
    debug mode only it is working, after hardware reset it is not working
    I have doubt in any hardware pin should be enable for UART bootloader as GPIO A 7 should be 1 or 0 ?
    Please confirm it because it is working in the Launchpad only.
  • VECTORS (X) : origin=0x00020020 length=0x00000020
    From your linker cmd file, the application starts address is 0x20020 rather than 0x20040. You need to modify the app start address in bl_config.h to 0x20020.
