Part Number: MSP432P401R
Sorry for the stupied question, but could someone help me what this function do? I found short explanation, because of my terrible english knowledge I did not understood.
Thank you in advance
LAszlo
LAszlo
Hi Laszlo,
You need to know the ADCBuf_adjustRawValues?
Is there some details about your question? This variable should used to store raw data for ADC. Have you encountered any problems in this area?
Thanks!
Best Regards
Johnson
Hello Johnson,
I am started a conversion program for wifi-pHmeter. At this stage, only differential values calculated with IQMath sent to Consol. The question is that should I use ADCBuf_adjustRawValues function or I can work with raw data of the CallbackFxn?
It is good to have calibrated ADC. For high drive sources, like NiMH battery, it measures more precisely than my Handy DVM. Using buffer amplifier, I can easily do one point zero calibration. For pH sensor, I have to calibrate the whole system, anyway; because of the behavior of the pH-sensor, so raw data would be enough.
LAszlo
Hi Laszlo,
Sorry that I am not familar with NiMH battery measurement, Could you tell me what I can do to help you with MSP432 MCU resource?
Thanks!
Best Regards
Johnson
