Due to the U.S. Thanksgiving holiday, please expect delayed responses during the week of 11/22.
AM2432: Pin mapping problem - SysConfig v1.9
Part Number: AM2432
Hello TI team,
I was configuring SysConfig v1.9 for my new AM2432 ALX based design, and I found out a mismatch between what I find in the datasheet (SPRSP65B) and what Sysconfig shows me.
In detail, in the datasheet I see pin G5 as VDDR_CORE and pin F5 as  PRG0_PRU1_GPO6, but SysConfig shows me the opposite, as highlighted in the image below:
Can you please clarify this point in order for me to correctly map the two pins in my design?
Thank you.
Flavio
  • Hello Flavio,
    The device datasheet is correct.
    G5 = VDDR_CORE
    F5 = PRG0_PRU1_GPO6
    This is a bug in the AM243x_ALX deviceData for the SysConfig tool. However, it will still correctly set the PADCONFIG_114 control register when configuring the PRG0_PRU1_GPO6 signal. We will work to resolve this issue in the deviceData file so it is correctly represented in the tool.
    Zackary Fleenor
  • Thank you Fleenor for the clarification. My design was aligned to the datasheet info, so your reply confirms it is correct.
    Thank you
    Flavio
