Hello
I am trying to build the project and the generate a .bin file and then copy that file to other location, Originally I have this in the post-build command:
"${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd" "${CG_TOOL_ROOT}/bin/armhex" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
this work perfect because I get the .bin file that I need.
then the problem start when I add some .bat files to the post-build field:
"${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd" "${CG_TOOL_ROOT}/bin/armhex" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin" "${CCE_INSTALL_ROOT}/post-build/test.bat"
in my test.bat file I have:
xcopy /f /s /y C:\Users\TM4C_TEST.bin C:\Users\TM4C\
where this TM4C_TEST.bin is direct generated by the compiler I think with the line mkhex4bin
so the problem that I have is that when I add "${CCE_INSTALL_ROOT}/post-build/test.bat" in the post-build step then CCS does NOT generate .bin file anymore.
maybe some suggestion how to do this?
