v6x - 6.1.4 not found in C2000_CLA_SAFETI_CQKIT_RV IDE, configuration, compiler or debugger | TI.com
Click the link , then left side "Select a version" , scroll down to the end , for v6x only 6.4.9 can be found.
Where can I find version 6.1.4?
For lower safety levels, customers have been able to generate the necessary documents from modifying a later QKIT version to an older compiler version that did not have a supported QKIT. The QKIT can be applied for ASIL-B with less constraints. However, for ASIL-D, the QKIT requires you run a coverage check and we do not have an instrumented set of compiler tools for 6.1.x releases. I would recommend upgrading to 6.4.9 which has the QKIT that includes instrumented binaries for the required coverage check at ASIL-D.
