LAUNCHXL-F28027F: DRV8353RS-EVM, LAUNCHXL-F28027F, ISO-F28027F
Part Number: LAUNCHXL-F28027F
Other Parts Discussed in Thread: DRV8353, DRV8353RS-EVM, MOTORWARE
We are using ISO-F28027F MCU Board interfaced with DRV8353RS-EVM Board to run the 48V BLDC Motor. We used lab05b code of  DRV8353 EVM firmware file for this in CCS software and followed all the steps provided in this manual ( DRV8353Rx-EVM InstaSPINTm Software Quick Start Guide (Rev. B) (ti.com) ). The motor spins fine through the GUI application. But, We would like to run the motor without using GUI and any external platform to control the motor operation, i.e, To run the motor directly by flashing a full program in the controller and operate the start and stop function with a switch. Is there any sample code or source available for this?
Thanks and Regards,
JESINTHA
  • You might refer to the link below to get the example codes and run the related labs within CCS.
    [FAQ] DRV8353RS-EVM with InstaSPIN and MotorWare support
    https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/921751
  • Hello Yanming,
    I referred to these programs previously. But, All these files are processed only through GUI. We couldn't find the exact solution to our request. As per the program, The enable parameters, User parameters are enabled in GUI and the Motor spinning is controlled through the Start and Stop option in DRV8353RX- GUI.  We need to know how to run the BLDC motor with a direct connection from the microcontroller without entering into GUI using a push switch or dip switch. We don't like to do any functions in GUI and want to directly flash the full code in MCU and operate using a switch. So, Can I get a solution for it that is suitable for the DRV8353RS Driver?
  • Please have a look at the E2E link mentioned above, these examples are used within CCS, not with GUI.
  • Thank you Yanming,
    Yes, Theses examples are used within CCS using the Motorware application. And the Motor spinning is controlled using Instaspin FOC Motorware Instrumentation which is a universal GUI for ISO-F28027F. But, Is there an option to control the motor with an external switch, to turn on and off the motor. We don't want any software application to control the motor spinning and wanted to spin manually by pressing a switch.
  • You might connect the input of  the external switch state and check the GPIO state. Set the gMotorVars.Flag_Run_Identify to 1 to start run the motor or 0 to stop i according to the state of the GPIO, and set gMotorVars.SpeedRef_krpm to the target speed you want.
  • Hello Yanming,
    Thank you for the response. I tried to connect the programmable Push button (GPIO12) available in the ISO-F28027F launchpad as per the instructions provided in the motorware Hal pdf (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwj0sqqt9LTyAhXC3jgGHWwkAhMQFnoECAMQAQ&url=https%3A%2F%2Fe2e.ti.com%2Fcfs-file%2F__key%2Fcommunityserver-discussions-components-files%2F171%2Fmotorware_5F00_hal_5F00_tutorial.pdf&usg=AOvVaw1NO-dhbc8mTJp3L7jyrjY6) But, I couldn't see the update in the watch window when it is pressed. I have attached the pictures for the reference. May I know do we need to change any other settings for this.
    And with the previous update shall I know where do we need to set the gMotorVars.Flag_Run_Identify to 1.
  • 1. Configure the GPIO to input in hal.c, and check its state in main loop or mainISR.
    2. You can set/clear the gMotorVars.Flag_Run_Identify in main loop or mainISR.
    If you haven't had a chance to look at the workshop material, I think this will help demystify some of the terminology and architecture as well.
    https://dev.ti.com/tirex/explore/node?node=AOXFCHdD4iiPtd8.R6R0Tw__jEBbtmC__LATEST
  • Thank you Yanming.
    Sorry for the delay in updating, I  tried to edit the code as per your suggestion. But, The value of GPIO 12 is not getting updated, when we press the switch. And, The program is not debugging completely, It gets stuck in the middle. I'm also getting the error such that, Memory map prevented reading. I have enclosed the image for reference. So Kindly, Let me know how to solve this issue.
  • It seems like you do more changes in the example lab project, not only add a function to read the GPIO for setting the start/stop. You might go back to the original example and just add a simple function for reading the GPIO to see what happens.
  • We didn't do any extra changes apart from the details provided in the datasheet for the motor params and the GPIO switch. I have attached the images of the places we edited in the code. Kindly help to solve this issue.
  • Does the lab run well on your kit if you don't do any changes in the example?
    Why do you add a variable to enable/disable the GPIOs for SPI? The GPIOs must be configured SPI always in the example project.
  • Yes, Yanming. The lab worked well.
     Hence, as per the datasheet, We used GPIO 12 push button which is the programmable push button available in the ISO-F28027F MCU. The status of the push button is read when it is at 0, and the motor has to run through enabling the controller. The status of the push button is read using a variable. Kindly let us know how to do proceed with this code.
  • If you haven't had a chance to look at the guide in motorWare, the guide has an example to read push button. And then you set the status to the gMotorVars.Flag_Run_Identify for start/stop the motor.
    motorware_hal_tutorial.pdf
    C:\ti\motorware\motorware_1_01_00_18\docs\tutorials
  • Hello Yanming, We did the changes to read the pushbuttons by following the Motorware hal tutorial pdf. I have mentioned this in the previous update.
    We have followed the instructions provided in the hal tutorial pdf- Pg.28, Reading push buttons.
  • As mentioned above, we have a very clear steps to tell you how to add the code and link the button state to start/stop the motor.
    Did you check if the state in the variable is right as you want when you press/release the button.
    If you still have question, please post the file you changed as an attachment. And have a description about how do you to connect the button the GPIO, it's better to have a picture to show it.
  • Yes, we checked the state in the variable. The state of the variable is default high, since it’s connected to 3V. When Button is pressed during the debugging process, the state is not updated. I have enclosed the snip of the expression window.
    When the Gpio 12 (Push Button) is pressed, the motor needs to start spinning. But, since the value it’s not getting updated, The Motor is not spinning.
    In order to check the error, we tried to set the gMotorVars.Flag_Run_Identify = true; in the Main ISR loop directly without setting inside any loop, the motor started spinning. So, the error is in the Push Button status update. We have attached the files we have updated for your reference.
    We didn't connect any external push-button for the GPIO. We are using the inbuilt button available in the ISO-F28027F microcontroller.
    proj_lab05b.c
    /* --COPYRIGHT--,BSD
     * Copyright (c) 2012, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     * --/COPYRIGHT--*/
    //! \file   solutions/instaspin_foc/src/proj_lab05b.c
    //! \brief Adjusting the speed controller
    //! (C) Copyright 2011, Texas Instruments, Inc.
    //! \defgroup PROJ_LAB05b PROJ_LAB05b
    //! \defgroup PROJ_LAB05b_OVERVIEW Project Overview
    //! Adjusting the supplied speed controller
    // the includes
    // system includes
    #include <math.h>
    #include "main.h"
    #ifdef FLASH
    #pragma CODE_SECTION(mainISR,"ramfuncs");
    #endif
    // Include header files used in the main function
    // the defines
    #define LED_BLINK_FREQ_Hz   5
    //! \brief Defines the GPIO pin number for drv8353 Switch 3
    #define HAL_GPIO_SW3 GPIO_Number_12
    // the globals
    uint_least16_t gCounter_updateGlobals = 0;
    bool Flag_Latch_softwareUpdate = true;
    bool gSw3;
    CTRL_Handle ctrlHandle;
    #ifdef CSM_ENABLE
    #pragma DATA_SECTION(halHandle,"rom_accessed_data");
    #endif
    HAL_Handle halHandle;
    #ifdef CSM_ENABLE
    #pragma DATA_SECTION(gUserParams,"rom_accessed_data");
    #endif
    USER_Params gUserParams;
    HAL_PwmData_t gPwmData = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};
    HAL_AdcData_t gAdcData;
    _iq gMaxCurrentSlope = _IQ(0.0);
    /*Motor ID*/
    _iq gLs_pu = _IQ30(0.0);
    uint_least8_t gLs_qFmt = 0;
    uint_least8_t gMax_Ls_qFmt = 0;
    #ifdef FAST_ROM_V1p6
    CTRL_Obj *controller_obj;
    #else
    #ifdef CSM_ENABLE
    #pragma DATA_SECTION(ctrl,"rom_accessed_data");
    #endif
    CTRL_Obj ctrl;				//v1p7 format
    #endif
    uint16_t gLEDcnt = 0;
    volatile MOTOR_Vars_t gMotorVars = MOTOR_Vars_INIT;
    //volatile DRV8x_Vars_t gDrv8xVars = DRV8x_Vars_INIT;
    _iq24 gPotentiometer = _IQ(0.0);
    uint16_t gDeviceVariant = 0xFF;
    #ifdef FLASH
    // Used for running BackGround in flash, and ISR in RAM
    extern uint16_t *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart;
    #ifdef CSM_ENABLE
    extern uint16_t *econst_start, *econst_end, *econst_ram_load;
    extern uint16_t *switch_start, *switch_end, *switch_ram_load;
    #endif
    #endif
    #ifdef DRV8301_SPI
    // Watch window interface to the 8301 SPI
    DRV_SPI_8301_Vars_t gDrvSpi8301Vars;
    #endif
    #ifdef DRV8305_SPI
    // Watch window interface to the 8305 SPI
    DRV_SPI_8305_Vars_t gDrvSpi8305Vars;
    #endif
    #ifdef DRV8353_SPI
    DRV_SPI_8353_Vars_t gDrvSpi8353Vars;
    #endif
    _iq gFlux_pu_to_Wb_sf;
    _iq gFlux_pu_to_VpHz_sf;
    _iq gTorque_Ls_Id_Iq_pu_to_Nm_sf;
    _iq gTorque_Flux_Iq_pu_to_Nm_sf;
    // the functions
    void main(void)
      uint_least8_t estNumber = 0;
      uint_least8_t ctrlNumber = 1;
    #endif
      // Only used if running from FLASH
      // Note that the variable FLASH is defined by the project
      #ifdef FLASH
      // Copy time critical code and Flash setup code to RAM
      // The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart
      // symbols are created by the linker. Refer to the linker files.
      memCopy((uint16_t *)&RamfuncsLoadStart,(uint16_t *)&RamfuncsLoadEnd,(uint16_t *)&RamfuncsRunStart);
      #ifdef CSM_ENABLE
        //copy .econst to unsecure RAM
        if(*econst_end - *econst_start)
            memCopy((uint16_t *)&econst_start,(uint16_t *)&econst_end,(uint16_t *)&econst_ram_load);
        //copy .switch ot unsecure RAM
        if(*switch_end - *switch_start)
            memCopy((uint16_t *)&switch_start,(uint16_t *)&switch_end,(uint16_t *)&switch_ram_load);
      #endif
      #endif
      // initialize the hardware abstraction layer
      halHandle = HAL_init(&hal,sizeof(hal));
      // check for errors in user parameters
      USER_checkForErrors(&gUserParams);
      // store user parameter error in global variable
      gMotorVars.UserErrorCode = USER_getErrorCode(&gUserParams);
      // do not allow code execution if there is a user parameter error
      if(gMotorVars.UserErrorCode != USER_ErrorCode_NoError)
          for(;;)
              gMotorVars.Flag_enableSys = false;
      // initialize the user parameters
      USER_setParams(&gUserParams);
      // set the hardware abstraction layer parameters
      HAL_setParams(halHandle,&gUserParams);
      // initialize the controller
      ctrlHandle = CTRL_initCtrl(ctrlNumber, estNumber);  		//v1p6 format (06xF and 06xM devices)
      controller_obj = (CTRL_Obj *)ctrlHandle;
    #else
      ctrlHandle = CTRL_initCtrl(estNumber,&ctrl,sizeof(ctrl));	//v1p7 format default
    #endif
        CTRL_Version version;
        // get the version number
        CTRL_getVersion(ctrlHandle,&version);
        gMotorVars.CtrlVersion = version;
      // set the default controller parameters
      CTRL_setParams(ctrlHandle,&gUserParams);
      // setup faults
      HAL_setupFaults(halHandle);
      // initialize the interrupt vector table
      HAL_initIntVectorTable(halHandle);
      // enable the ADC interrupts
      HAL_enableAdcInts(halHandle);
      // enable global interrupts
      HAL_enableGlobalInts(halHandle);
      // enable debug interrupts
      HAL_enableDebugInt(halHandle);
      // disable the PWM
      HAL_disablePwm(halHandle);
    #ifdef DRV8301_SPI
      // turn on the DRV8301 if present
      HAL_enableDrv(halHandle);
      // initialize the DRV8301 interface
      HAL_setupDrvSpi(halHandle,&gDrvSpi8301Vars);
    #endif
    #ifdef DRV8305_SPI
      // turn on the DRV8305 if present
      // initialize the DRV8305 interface
      HAL_setupDrvSpi(halHandle,&gDrvSpi8305Vars);
    #endif
    #ifdef DRV8353
    #endif
    #ifdef DRV8353_SPI
      // initialize the DRV8353 interface
      if(gDeviceVariant)
    	  HAL_setupDrvSpi(halHandle,&gDrvSpi8353Vars);
    #endif
      // enable DC bus compensation
      CTRL_setFlag_enableDcBusComp(ctrlHandle, true);
      // compute scaling factors for flux and torque calculations
      gFlux_pu_to_Wb_sf = USER_computeFlux_pu_to_Wb_sf();
      gFlux_pu_to_VpHz_sf = USER_computeFlux_pu_to_VpHz_sf();
      gTorque_Ls_Id_Iq_pu_to_Nm_sf = USER_computeTorque_Ls_Id_Iq_pu_to_Nm_sf();
      gTorque_Flux_Iq_pu_to_Nm_sf = USER_computeTorque_Flux_Iq_pu_to_Nm_sf();
        gPotentiometer = HAL_readPotentiometerData(halHandle);
        if((gPotentiometer) < USER_DRVID_ADC_V)
    	  gDeviceVariant = DRV8353RS;
    	else
    	  gDeviceVariant = DRV8353RH;
      for(;;)
        // Waiting for enable system flag to be set
    //*    while(!(gMotorVars.Flag_enableSys));
          gMotorVars.Flag_enableSys = true;
        // Enable the Library internal PI.  Iq is referenced by the speed PI now
        CTRL_setFlag_enableSpeedCtrl(ctrlHandle, true);
        // loop while the enable system flag is true
        while(gMotorVars.Flag_enableSys)
            CTRL_Obj *obj = (CTRL_Obj *)ctrlHandle;
            // increment counters
            gCounter_updateGlobals++;
            if(gMotorVars.Flag_updateUserdoth)
                // set the enable controller flag to false
                CTRL_setFlag_enableCtrl(ctrlHandle,false);
                // disable the PWM
                gMotorVars.Flag_Run_Identify = 0;
                gMotorVars.Flag_updateUserdoth = 0;
            // enable/disable the use of motor parameters being loaded from user.h
            CTRL_setFlag_enableUserMotorParams(ctrlHandle,gMotorVars.Flag_enableUserParams);
            // enable/disable Rs recalibration during motor startup
            EST_setFlag_enableRsRecalc(obj->estHandle,gMotorVars.Flag_enableRsRecalc);
            // enable/disable automatic calculation of bias values
            CTRL_setFlag_enableOffset(ctrlHandle,gMotorVars.Flag_enableOffsetcalc);
            if(CTRL_isError(ctrlHandle))
                // set the enable system flag to false
                // disable the PWM
            else
                // update the controller state
                bool flag_ctrlStateChanged = CTRL_updateState(ctrlHandle);
                // enable or disable the control
                CTRL_setFlag_enableCtrl(ctrlHandle, gMotorVars.Flag_Run_Identify);
                if(flag_ctrlStateChanged)
                    CTRL_State_e ctrlState = CTRL_getState(ctrlHandle);
                    /* Motor Identification*/
                    EST_State_e estState = EST_getState(obj->estHandle);
                    if(ctrlState == CTRL_State_OffLine)
                        // enable the PWM
                        HAL_enablePwm(halHandle);
                    else if(ctrlState == CTRL_State_OnLine)
                    	if(((estState < EST_State_LockRotor) || (estState > EST_State_MotorIdentified)) && (!gMotorVars.Flag_updateUserdoth))
                        //if(gMotorVars.Flag_enableOffsetcalc == true)
                          // update the ADC bias values
                          HAL_updateAdcBias(halHandle);
                        else
                          // set the current bias
                          HAL_setBias(halHandle,HAL_SensorType_Current,0,_IQ(I_A_offset));
                          HAL_setBias(halHandle,HAL_SensorType_Current,1,_IQ(I_B_offset));
                          HAL_setBias(halHandle,HAL_SensorType_Current,2,_IQ(I_C_offset));
                          // set the voltage bias
                          HAL_setBias(halHandle,HAL_SensorType_Voltage,0,_IQ(V_A_offset));
                          HAL_setBias(halHandle,HAL_SensorType_Voltage,1,_IQ(V_B_offset));
                          HAL_setBias(halHandle,HAL_SensorType_Voltage,2,_IQ(V_C_offset));
                        // Return the bias value for currents
                        gMotorVars.I_bias.value[0] = HAL_getBias(halHandle,HAL_SensorType_Current,0);
                        gMotorVars.I_bias.value[1] = HAL_getBias(halHandle,HAL_SensorType_Current,1);
                        gMotorVars.I_bias.value[2] = HAL_getBias(halHandle,HAL_SensorType_Current,2);
                        // Return the bias value for voltages
                        gMotorVars.V_bias.value[0] = HAL_getBias(halHandle,HAL_SensorType_Voltage,0);
                        gMotorVars.V_bias.value[1] = HAL_getBias(halHandle,HAL_SensorType_Voltage,1);
                        gMotorVars.V_bias.value[2] = HAL_getBias(halHandle,HAL_SensorType_Voltage,2);
                        // enable the PWM
                    else if(ctrlState == CTRL_State_Idle)
                        // disable the PWM
                        gMotorVars.Flag_Run_Identify = false;
                    if((CTRL_getFlag_enableUserMotorParams(ctrlHandle) == true) &&
                      (ctrlState > CTRL_State_Idle) &&
                      (gMotorVars.CtrlVersion.minor == 6))
                        // call this function to fix 1p6
                        USER_softwareUpdate1p6(ctrlHandle);
            if((EST_isMotorIdentified(obj->estHandle)) && (!(gMotorVars.Flag_updateUserdoth)))
                // set the current ramp
                EST_setMaxCurrentSlope_pu(obj->estHandle,gMaxCurrentSlope);
                gMotorVars.Flag_MotorIdentified = true;
                // set the speed reference
                CTRL_setSpd_ref_krpm(ctrlHandle,gMotorVars.SpeedRef_krpm);
                // set the speed acceleration
                CTRL_setMaxAccel_pu(ctrlHandle,_IQmpy(MAX_ACCEL_KRPMPS_SF,gMotorVars.MaxAccel_krpmps));
                if(Flag_Latch_softwareUpdate)
                  Flag_Latch_softwareUpdate = false;
                  USER_calcPIgains(ctrlHandle);
                  // initialize the watch window kp and ki current values with pre-calculated values
                  gMotorVars.Kp_Idq = CTRL_getKp(ctrlHandle,CTRL_Type_PID_Id);
                  gMotorVars.Ki_Idq = CTRL_getKi(ctrlHandle,CTRL_Type_PID_Id);
                  // initialize the watch window kp and ki values with pre-calculated values
                  gMotorVars.Kp_spd = CTRL_getKp(ctrlHandle,CTRL_Type_PID_spd);
                  gMotorVars.Ki_spd = CTRL_getKi(ctrlHandle,CTRL_Type_PID_spd);
            else
                // the estimator sets the maximum current slope during identification
                gMaxCurrentSlope = EST_getMaxCurrentSlope_pu(obj->estHandle);
            // when appropriate, update the global variables
            if(gCounter_updateGlobals >= NUM_MAIN_TICKS_FOR_GLOBAL_VARIABLE_UPDATE)
                // reset the counter
                updateGlobalVariables_motor(ctrlHandle);
            /*Motor Identification*/
            if((CTRL_getMotorType(ctrlHandle) == MOTOR_Type_Induction) && (!gMotorVars.Flag_updateUserdoth))
                // recalculate Kp and Ki gains to fix the R/L limitation of 2000.0, and Kp limit to 0.11
                recalcKpKi(ctrlHandle);
                // set electrical frequency limit to zero while identifying an induction motor
                setFeLimitZero(ctrlHandle);
                // calculate Dir_qFmt for acim motors
                acim_Dir_qFmtCalc(ctrlHandle);
            else
            	// as well as recalculates gains based on estimator state to allow low inductance pmsm to id
            	recalcKpKiPmsm(ctrlHandle);
                // calculate an Ls qFmt that allows ten times smaller inductance compared to Lhf
                CTRL_calcMax_Ls_qFmt(ctrlHandle, &gMax_Ls_qFmt);
                gLs_pu = EST_getLs_d_pu(obj->estHandle);
                gLs_qFmt = EST_getLs_qFmt(obj->estHandle);
            // update Kp and Ki gains
            //updateKpKiGains(ctrlHandle);
            // enable/disable the forced angle
            EST_setFlag_enableForceAngle(obj->estHandle,gMotorVars.Flag_enableForceAngle);
            // enable or disable power warp
            CTRL_setFlag_enablePowerWarp(ctrlHandle,gMotorVars.Flag_enablePowerWarp);
    #ifdef DRV8301_SPI
            HAL_writeDrvData(halHandle,&gDrvSpi8301Vars);
            HAL_readDrvData(halHandle,&gDrvSpi8301Vars);
    #endif
    #ifdef DRV8305_SPI
            HAL_writeDrvData(halHandle,&gDrvSpi8305Vars);
            HAL_readDrvData(halHandle,&gDrvSpi8305Vars);
    #endif
    #ifdef DRV8353_SPI
            if(gDeviceVariant)
    			HAL_writeDrvData(halHandle,&gDrvSpi8353Vars);
    			HAL_readDrvData(halHandle,&gDrvSpi8353Vars);
    #endif
          } // end of while(gFlag_enableSys) loop
        // disable the PWM
        // set the default controller parameters (Reset the control to re-identify the motor)
      } // end of for(;;) loop
    } // end of main() function
    interrupt void mainISR(void)
      // toggle status LED
      if(++gLEDcnt >= (uint_least32_t)(USER_ISR_FREQ_Hz / LED_BLINK_FREQ_Hz))
        HAL_toggleLed(halHandle,(GPIO_Number_e)HAL_Gpio_LED2);
        gLEDcnt = 0;
      // To call the function and assign the value.
    //*  gSw3=HAL_readGpio(halHandle, HAL_GPIO_SW3);
      // To call the function and assign the value, To start and stop the motor.
      // enable or disable the system
      gSw3 = HAL_readGpio(halHandle, HAL_GPIO_SW3);
      if (gSw3==false)
      else
      // acknowledge the ADC interrupt
      HAL_acqAdcInt(halHandle,ADC_IntNumber_1);
      // convert the ADC data
      HAL_readAdcData(halHandle,&gAdcData);
      // run the controller
      CTRL_run(ctrlHandle,halHandle,&gAdcData,&gPwmData);
      // write the PWM compare values
      HAL_writePwmData(halHandle,&gPwmData);
      // setup the controller
      CTRL_setup(ctrlHandle);
      if(CTRL_getMotorType(ctrlHandle) == MOTOR_Type_Pm)
          // reset Ls Q format to a higher value when Ls identification starts
          CTRL_resetLs_qFmt(ctrlHandle, gMax_Ls_qFmt);
      return;
    } // end of mainISR() function
    void updateGlobalVariables_motor(CTRL_Handle handle)
      CTRL_Obj *obj = (CTRL_Obj *)handle;
      // get the speed estimate
      gMotorVars.Speed_krpm = EST_getSpeed_krpm(obj->estHandle);
      // get the real time speed reference coming out of the speed trajectory generator
      gMotorVars.SpeedTraj_krpm = _IQmpy(CTRL_getSpd_int_ref_pu(handle),EST_get_pu_to_krpm_sf(obj->estHandle));
      // get the torque estimate
      gMotorVars.Torque_Nm = USER_computeTorque_Nm(handle, gTorque_Flux_Iq_pu_to_Nm_sf, gTorque_Ls_Id_Iq_pu_to_Nm_sf);
      // get the magnetizing current
      gMotorVars.MagnCurr_A = EST_getIdRated(obj->estHandle);
      // get the rotor resistance
      gMotorVars.Rr_Ohm = EST_getRr_Ohm(obj->estHandle);
      // get the stator resistance
      gMotorVars.Rs_Ohm = EST_getRs_Ohm(obj->estHandle);
      // get the stator inductance in the direct coordinate direction
      gMotorVars.Lsd_H = EST_getLs_d_H(obj->estHandle);
      // get the stator inductance in the quadrature coordinate direction
      gMotorVars.Lsq_H = EST_getLs_q_H(obj->estHandle);
      // get the flux in V/Hz in floating point
      gMotorVars.Flux_VpHz = EST_getFlux_VpHz(obj->estHandle);
      // get the flux in Wb in fixed point
      gMotorVars.Flux_Wb = USER_computeFlux(handle, gFlux_pu_to_Wb_sf);
      // get the controller state
      gMotorVars.CtrlState = CTRL_getState(handle);
      // get the estimator state
      gMotorVars.EstState = EST_getState(obj->estHandle);
      // Get the DC buss voltage
      gMotorVars.VdcBus_kV = _IQmpy(gAdcData.dcBus,_IQ(USER_IQ_FULL_SCALE_VOLTAGE_V/1000.0));
      return;
    } // end of updateGlobalVariables_motor() function
    void updateKpKiGains(CTRL_Handle handle)
      if((gMotorVars.CtrlState == CTRL_State_OnLine) && (gMotorVars.Flag_MotorIdentified == true) && (Flag_Latch_softwareUpdate == false))
          // set the kp and ki speed values from the watch window
          CTRL_setKp(handle,CTRL_Type_PID_spd,gMotorVars.Kp_spd);
          CTRL_setKi(handle,CTRL_Type_PID_spd,gMotorVars.Ki_spd);
          // set the kp and ki current values for Id and Iq from the watch window
          CTRL_setKp(handle,CTRL_Type_PID_Id,gMotorVars.Kp_Idq);
          CTRL_setKi(handle,CTRL_Type_PID_Id,gMotorVars.Ki_Idq);
          CTRL_setKp(handle,CTRL_Type_PID_Iq,gMotorVars.Kp_Idq);
          CTRL_setKi(handle,CTRL_Type_PID_Iq,gMotorVars.Ki_Idq);
      return;
    } // end of updateKpKiGains() function
    void CTRL_resetLs_qFmt(CTRL_Handle handle, const uint_least8_t Ls_qFmt)
      static bool LsResetLatch = false;
      if(EST_getState(obj->estHandle) == EST_State_Ls)
          if((EST_getLs_d_pu(obj->estHandle) != _IQ30(0.0)) && (LsResetLatch == false))
              EST_setLs_qFmt(obj->estHandle, Ls_qFmt);
              LsResetLatch = true;
      else
      return;
    } // end of CTRL_resetLs_qFmt() function
    void recalcKpKiPmsm(CTRL_Handle handle)
      EST_State_e EstState = EST_getState(obj->estHandle);
      if((EST_isMotorIdentified(obj->estHandle) == false) && (EstState == EST_State_Rs))
          float_t Lhf = CTRL_getLhf(handle);
          float_t Rhf = CTRL_getRhf(handle);
          float_t RhfoverLhf = Rhf/Lhf;
          _iq Kp = _IQ(0.05*Lhf*USER_IQ_FULL_SCALE_CURRENT_A/(USER_CTRL_PERIOD_sec*USER_IQ_FULL_SCALE_VOLTAGE_V));
          _iq Ki = _IQ(RhfoverLhf*USER_CTRL_PERIOD_sec);
          _iq Kp_spd = _IQ(0.005*USER_IQ_FULL_SCALE_FREQ_Hz*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
          // set Rhf/Lhf
          CTRL_setRoverL(handle,RhfoverLhf);
          // set the controller proportional gains
          CTRL_setKp(handle,CTRL_Type_PID_Id,Kp);
          CTRL_setKp(handle,CTRL_Type_PID_Iq,Kp);
          // set the Id controller gains
          CTRL_setKi(handle,CTRL_Type_PID_Id,Ki);
          PID_setKi(obj->pidHandle_Id,Ki);
          // set the Iq controller gains
          CTRL_setKi(handle,CTRL_Type_PID_Iq,Ki);
          PID_setKi(obj->pidHandle_Iq,Ki);
          // set speed gains
          PID_setKp(obj->pidHandle_spd,Kp_spd);
      else if(EstState == EST_State_RatedFlux)
          _iq Ki_spd = _IQ(0.5*USER_IQ_FULL_SCALE_FREQ_Hz*USER_CTRL_PERIOD_sec*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
          // Set Ki on closing the feedback loop
          PID_setKi(obj->pidHandle_spd,Ki_spd);
      else if(EstState == EST_State_RampDown)
          _iq Kp_spd = _IQ(0.02*USER_IQ_FULL_SCALE_FREQ_Hz*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
          _iq Ki_spd = _IQ(2.0*USER_IQ_FULL_SCALE_FREQ_Hz*USER_CTRL_PERIOD_sec*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
          // Set Kp and Ki of the speed controller
          TRAJ_setTargetValue(obj->trajHandle_spdMax,_IQ(USER_MOTOR_RES_EST_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A));
      return;
    } // end of recalcKpKiPmsm() function
    void CTRL_calcMax_Ls_qFmt(CTRL_Handle handle, uint_least8_t *pLs_qFmt)
      if((EST_isMotorIdentified(obj->estHandle) == false) && (EST_getState(obj->estHandle) == EST_State_Rs))
    	  float_t fullScaleInductance = USER_IQ_FULL_SCALE_VOLTAGE_V/(USER_IQ_FULL_SCALE_CURRENT_A*USER_VOLTAGE_FILTER_POLE_rps);
    	  float_t Ls_coarse_max = _IQ30toF(EST_getLs_coarse_max_pu(obj->estHandle));
    	  int_least8_t lShift = ceil(log((Lhf/20.0)/(Ls_coarse_max*fullScaleInductance))/log(2.0));
    	  *pLs_qFmt = 30 - lShift;
      return;
    } // end of CTRL_calcMax_Ls_qFmt() function
    void recalcKpKi(CTRL_Handle handle)
          _iq Kp = _IQ(0.25*Lhf*USER_IQ_FULL_SCALE_CURRENT_A/(USER_CTRL_PERIOD_sec*USER_IQ_FULL_SCALE_VOLTAGE_V));
          // set Rhf/Lhf
      return;
    } // end of recalcKpKi() function
    void setFeLimitZero(CTRL_Handle handle)
      _iq fe_neg_max_pu;
      _iq fe_pos_min_pu;
      if((EST_isMotorIdentified(obj->estHandle) == false) && (CTRL_getMotorType(handle) == MOTOR_Type_Induction))
    	  fe_neg_max_pu = _IQ30(0.0);
    	  fe_pos_min_pu = _IQ30(0.0);
      else
    	  fe_neg_max_pu = _IQ30(-USER_ZEROSPEEDLIMIT);
    	  fe_pos_min_pu = _IQ30(USER_ZEROSPEEDLIMIT);
      EST_setFe_neg_max_pu(obj->estHandle, fe_neg_max_pu);
      EST_setFe_pos_min_pu(obj->estHandle, fe_pos_min_pu);
      return;
    } // end of setFeLimitZero() function
    void acim_Dir_qFmtCalc(CTRL_Handle handle)
      if(EstState == EST_State_IdRated)
          EST_setDir_qFmt(obj->estHandle, EST_computeDirection_qFmt(obj->estHandle, 0.7));
      return;
    } // end of acim_Dir_qFmtCalc() function
    //@} //defgroup
    // end of file
    7120.hal.h
    5367.hal.c
     * Copyright (c) 2015, Texas Instruments Incorporated
     * are met:
     * --/COPYRIGHT--*/
    //! \file  sw/modules/hal/boards/boostxldrv8353/f28x/f2802xF/src/hal.c
    //! \brief Contains the various functions related to the HAL object (everything outside the CTRL system)
    //! (C) Copyright 2015, Texas Instruments, Inc.
    // the includes
    // drivers
    // modules
    // platforms
    #include "hal.h"
    #include "user.h"
    #include "hal_obj.h"
    #ifdef FLASH
    #pragma CODE_SECTION(HAL_setupFlash,"ramfuncs");
    #endif
    // the defines
    #define US_TO_CNT(A) ((((long double) A * (long double)USER_SYSTEM_FREQ_MHz) - 9.0L) / 5.0L)
    // the globals
    #ifdef F2802xF
    #pragma DATA_SECTION(hal,"rom_accessed_data");
    #endif
    HAL_Obj hal;
    // the functions
    void HAL_cal(HAL_Handle handle)
      HAL_Obj *obj = (HAL_Obj *)handle;
      // enable the ADC clock
      CLK_enableAdcClock(obj->clkHandle);
      // Run the Device_cal() function
      // This function copies the ADC and oscillator calibration values from TI reserved
      // OTP into the appropriate trim registers
      // This boot ROM automatically calls this function to calibrate the interal
      // oscillators and ADC with device specific calibration data.
      // If the boot ROM is bypassed by Code Composer Studio during the development process,
      // then the calibration must be initialized by the application
      ENABLE_PROTECTED_REGISTER_WRITE_MODE;
      (*Device_cal)();
      DISABLE_PROTECTED_REGISTER_WRITE_MODE;
      // run offsets calibration in user's memory
      HAL_AdcOffsetSelfCal(handle);
      // run oscillator compensation
      HAL_OscTempComp(handle);
      // disable the ADC clock
      CLK_disableAdcClock(obj->clkHandle);
      return;
    } // end of HAL_cal() function
    void HAL_OscTempComp(HAL_Handle handle)
      uint16_t Temperature;
      // disable the ADCs
      ADC_disable(obj->adcHandle);
      // power up the bandgap circuit
      ADC_enableBandGap(obj->adcHandle);
      // set the ADC voltage reference source to internal
      ADC_setVoltRefSrc(obj->adcHandle,ADC_VoltageRefSrc_Int);
      // enable the ADC reference buffers
      ADC_enableRefBuffers(obj->adcHandle);
      // Set main clock scaling factor (max45MHz clock for the ADC module)
      ADC_setDivideSelect(obj->adcHandle,ADC_DivideSelect_ClkIn_by_2);
      // power up the ADCs
      ADC_powerUp(obj->adcHandle);
      // enable the ADCs
      ADC_enable(obj->adcHandle);
      // enable non-overlap mode
      ADC_enableNoOverlapMode(obj->adcHandle);
      // connect channel A5 internally to the temperature sensor
      ADC_setTempSensorSrc(obj->adcHandle, ADC_TempSensorSrc_Int);
      // set SOC0 channel select to ADCINA5
      ADC_setSocChanNumber(obj->adcHandle, ADC_SocNumber_0, ADC_SocChanNumber_A5);
      // set SOC0 acquisition period to 26 ADCCLK
      ADC_setSocSampleDelay(obj->adcHandle, ADC_SocNumber_0, ADC_SocSampleDelay_64_cycles);
      // connect ADCINT1 to EOC0
      ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_1, ADC_IntSrc_EOC0);
      // clear ADCINT1 flag
      ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_1);
      // enable ADCINT1
      ADC_enableInt(obj->adcHandle, ADC_IntNumber_1);
      // force start of conversion on SOC0
      ADC_setSocFrc(obj->adcHandle, ADC_SocFrc_0);
      // wait for end of conversion
      while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_1) == 0){}
      Temperature = ADC_readResult(obj->adcHandle, ADC_ResultNumber_0);
      HAL_osc1Comp(handle, Temperature);
      HAL_osc2Comp(handle, Temperature);
      return;
    } // end of HAL_OscTempComp() function
    void HAL_osc1Comp(HAL_Handle handle, const int16_t sensorSample)
    	int16_t compOscFineTrim;
        compOscFineTrim = ((sensorSample - getRefTempOffset())*(int32_t)getOsc1FineTrimSlope()
                          + OSC_POSTRIM_OFF + FP_ROUND )/FP_SCALE + getOsc1FineTrimOffset() - OSC_POSTRIM;
        if(compOscFineTrim > 31)
            compOscFineTrim = 31;
    	else if(compOscFineTrim < -31)
            compOscFineTrim = -31;
        OSC_setTrim(obj->oscHandle, OSC_Number_1, HAL_getOscTrimValue(getOsc1CoarseTrim(), compOscFineTrim));
        return;
    } // end of HAL_osc1Comp() function
    void HAL_osc2Comp(HAL_Handle handle, const int16_t sensorSample)
        compOscFineTrim = ((sensorSample - getRefTempOffset())*(int32_t)getOsc2FineTrimSlope()
                          + OSC_POSTRIM_OFF + FP_ROUND )/FP_SCALE + getOsc2FineTrimOffset() - OSC_POSTRIM;
        OSC_setTrim(obj->oscHandle, OSC_Number_2, HAL_getOscTrimValue(getOsc2CoarseTrim(), compOscFineTrim));
        return;
    } // end of HAL_osc2Comp() function
    uint16_t HAL_getOscTrimValue(int16_t coarse, int16_t fine)
      uint16_t regValue = 0;
      if(fine < 0)
          regValue = ((-fine) | 0x20) << 9;
      else
          regValue = fine << 9;
      if(coarse < 0)
          regValue |= ((-coarse) | 0x80);
      else
          regValue |= coarse;
      return regValue;
    } // end of HAL_getOscTrimValue() function
    void HAL_AdcOffsetSelfCal(HAL_Handle handle)
      uint16_t AdcConvMean;
      // disable the ADCs
      // enable the ADCs
      //Select VREFLO internal connection on B5
      ADC_enableVoltRefLoConv(obj->adcHandle);
      //Select channel B5 for all SOC
      HAL_AdcCalChanSelect(handle, ADC_SocChanNumber_B5);
      //Apply artificial offset (+80) to account for a negative offset that may reside in the ADC core
      ADC_setOffTrim(obj->adcHandle, 80);
      //Capture ADC conversion on VREFLO
      AdcConvMean = HAL_AdcCalConversion(handle);
      //Set offtrim register with new value (i.e remove artical offset (+80) and create a two's compliment of the offset error)
      ADC_setOffTrim(obj->adcHandle, 80 - AdcConvMean);
      //Select external ADCIN5 input pin on B5
      ADC_disableVoltRefLoConv(obj->adcHandle);
      return;
    } // end of HAL_AdcOffsetSelfCal() function
    void HAL_AdcCalChanSelect(HAL_Handle handle, const ADC_SocChanNumber_e chanNumber)
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_8,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_9,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_10,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_11,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_12,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_13,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_14,chanNumber);
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_15,chanNumber);
      return;
    } // end of HAL_AdcCalChanSelect() function
    uint16_t HAL_AdcCalConversion(HAL_Handle handle)
      uint16_t index, SampleSize, Mean;
      uint32_t Sum;
      ADC_SocSampleDelay_e ACQPS_Value;
      index       = 0;     //initialize index to 0
      SampleSize  = 256;   //set sample size to 256 (**NOTE: Sample size must be multiples of 2^x where is an integer >= 4)
      Sum         = 0;     //set sum to 0
      Mean        = 999;   //initialize mean to known value
      //Set the ADC sample window to the desired value (Sample window = ACQPS + 1)
      ACQPS_Value = ADC_SocSampleDelay_7_cycles;
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_8,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_9,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_10,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_11,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_12,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_13,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_14,ACQPS_Value);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_15,ACQPS_Value);
      // Enabled ADCINT1 and ADCINT2
      ADC_enableInt(obj->adcHandle, ADC_IntNumber_2);
      // Disable continuous sampling for ADCINT1 and ADCINT2
      ADC_setIntMode(obj->adcHandle, ADC_IntNumber_1, ADC_IntMode_EOC);
      ADC_setIntMode(obj->adcHandle, ADC_IntNumber_2, ADC_IntMode_EOC);
      //ADCINTs trigger at end of conversion
      ADC_setIntPulseGenMode(obj->adcHandle, ADC_IntPulseGenMode_Prior);
      // Setup ADCINT1 and ADCINT2 trigger source
      ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_1, ADC_IntSrc_EOC6);
      ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_2, ADC_IntSrc_EOC14);
      // Setup each SOC's ADCINT trigger source
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_0, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_1, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_2, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_3, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_4, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_5, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_6, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_7, ADC_Int2TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_10, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_11, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_12, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_13, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_14, ADC_Int1TriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_15, ADC_Int1TriggersSOC);
      // Delay before converting ADC channels
      usDelay(US_TO_CNT(ADC_DELAY_usec));
      ADC_setSocFrcWord(obj->adcHandle, 0x00FF);
      while( index < SampleSize )
          //Wait for ADCINT1 to trigger, then add ADCRESULT0-7 registers to sum
          //Must clear ADCINT1 flag since INT1CONT = 0
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_0);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_1);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_2);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_3);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_4);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_5);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_6);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_7);
          //Wait for ADCINT2 to trigger, then add ADCRESULT8-15 registers to sum
          while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_2) == 0){}
          //Must clear ADCINT2 flag since INT2CONT = 0
          ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_2);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_8);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_9);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_10);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_11);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_12);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_13);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_14);
          Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_15);
          index+=16;
      } // end data collection
      //Disable ADCINT1 and ADCINT2 to STOP the ping-pong sampling
      ADC_disableInt(obj->adcHandle, ADC_IntNumber_1);
      ADC_disableInt(obj->adcHandle, ADC_IntNumber_2);
      //Calculate average ADC sample value
      Mean = Sum / SampleSize;
      // Clear start of conversion trigger
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_0, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_1, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_2, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_3, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_4, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_5, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_6, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_7, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_10, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_11, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_12, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_13, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_14, ADC_NoIntTriggersSOC);
      ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_15, ADC_NoIntTriggersSOC);
      //return the average
      return(Mean);
    } // end of HAL_AdcCalConversion() function
    void HAL_disableWdog(HAL_Handle halHandle)
      HAL_Obj *hal = (HAL_Obj *)halHandle;
      WDOG_disable(hal->wdogHandle);
      return;
    } // end of HAL_disableWdog() function
    void HAL_disableGlobalInts(HAL_Handle handle)
      CPU_disableGlobalInts(obj->cpuHandle);
      return;
    } // end of HAL_disableGlobalInts() function
    void HAL_enableAdcInts(HAL_Handle handle)
      // enable the PIE interrupts associated with the ADC interrupts
      PIE_enableAdcInt(obj->pieHandle,ADC_IntNumber_1);
      ADC_enableInt(obj->adcHandle,ADC_IntNumber_1);
      // enable the cpu interrupt for ADC interrupts
      CPU_enableInt(obj->cpuHandle,CPU_IntNumber_10);
      return;
    } // end of HAL_enableAdcInts() function
    void HAL_enableDebugInt(HAL_Handle handle)
      CPU_enableDebugInt(obj->cpuHandle);
      return;
    } // end of HAL_enableDebugInt() function
    void HAL_enableDrv(HAL_Handle handle)
      DRV8353_enable(obj->drv8353Handle);
      return;
    }  // end of HAL_enableDrv() function
    void HAL_enableGlobalInts(HAL_Handle handle)
      CPU_enableGlobalInts(obj->cpuHandle);
      return;
    } // end of HAL_enableGlobalInts() function
    void HAL_enablePwmInt(HAL_Handle handle)
      PIE_enablePwmInt(obj->pieHandle,PWM_Number_1);
      // enable the interrupt
      PWM_enableInt(obj->pwmHandle[PWM_Number_1]);
      // enable the cpu interrupt for EPWM1_INT
      CPU_enableInt(obj->cpuHandle,CPU_IntNumber_3);
      return;
    } // end of HAL_enablePwmInt() function
    void HAL_setupFaults(HAL_Handle handle)
      uint_least8_t cnt;
      // Configure Trip Mechanism for the Motor control software
      // -Cycle by cycle trip on CPU halt
      // -One shot fault trip zone
      // These trips need to be repeated for EPWM1 ,2 & 3
      for(cnt=0;cnt<3;cnt++)
          PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ6_NOT);
    //    PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ2_NOT);
          // What do we want the OST/CBC events to do?
          // TZA events can force EPWMxA
          // TZB events can force EPWMxB
          PWM_setTripZoneState_TZA(obj->pwmHandle[cnt],PWM_TripZoneState_EPWM_Low);
          PWM_setTripZoneState_TZB(obj->pwmHandle[cnt],PWM_TripZoneState_EPWM_Low);
      return;
    } // end of HAL_setupFaults() function
    HAL_Handle HAL_init(void *pMemory,const size_t numBytes)
      uint_least8_t cnt;
      HAL_Handle handle;
      HAL_Obj *obj;
      if(numBytes < sizeof(HAL_Obj))
        return((HAL_Handle)NULL);
      // assign the handle
      handle = (HAL_Handle)pMemory;
      // assign the object
      // initialize the watchdog driver
      obj->wdogHandle = WDOG_init((void *)WDOG_BASE_ADDR,sizeof(WDOG_Obj));
      // disable watchdog
      HAL_disableWdog(handle);
      // initialize the ADC
      obj->adcHandle = ADC_init((void *)ADC_BASE_ADDR,sizeof(ADC_Obj));
      // initialize the clock handle
      obj->clkHandle = CLK_init((void *)CLK_BASE_ADDR,sizeof(CLK_Obj));
      // initialize the CPU handle
      obj->cpuHandle = CPU_init(&cpu,sizeof(cpu));
      // initialize the FLASH handle
      obj->flashHandle = FLASH_init((void *)FLASH_BASE_ADDR,sizeof(FLASH_Obj));
      // initialize the GPIO handle
      obj->gpioHandle = GPIO_init((void *)GPIO_BASE_ADDR,sizeof(GPIO_Obj));
      // initialize the current offset estimator handles
      for(cnt=0;cnt<USER_NUM_CURRENT_SENSORS;cnt++)
          obj->offsetHandle_I[cnt] = OFFSET_init(&obj->offset_I[cnt],sizeof(obj->offset_I[cnt]));
      // initialize the voltage offset estimator handles
      for(cnt=0;cnt<USER_NUM_VOLTAGE_SENSORS;cnt++)
          obj->offsetHandle_V[cnt] = OFFSET_init(&obj->offset_V[cnt],sizeof(obj->offset_V[cnt]));
      // initialize the oscillator handle
      obj->oscHandle = OSC_init((void *)OSC_BASE_ADDR,sizeof(OSC_Obj));
      // initialize the PIE handle
      obj->pieHandle = PIE_init((void *)PIE_BASE_ADDR,sizeof(PIE_Obj));
      // initialize the PLL handle
      obj->pllHandle = PLL_init((void *)PLL_BASE_ADDR,sizeof(PLL_Obj));
    #ifdef DRV8353_SPI
      // initialize the SPIA handle
      if(gDeviceVariant)
    	  obj->spiAHandle = SPI_init((void *)SPIA_BASE_ADDR,sizeof(SPI_Obj));
    #endif
      // initialize PWM handle
      obj->pwmHandle[0] = PWM_init((void *)PWM_ePWM1_BASE_ADDR,sizeof(PWM_Obj));
      obj->pwmHandle[1] = PWM_init((void *)PWM_ePWM2_BASE_ADDR,sizeof(PWM_Obj));
      obj->pwmHandle[2] = PWM_init((void *)PWM_ePWM3_BASE_ADDR,sizeof(PWM_Obj));
      // initialize power handle
      obj->pwrHandle = PWR_init((void *)PWR_BASE_ADDR,sizeof(PWR_Obj));
      // initialize timer drivers
      obj->timerHandle[0] = TIMER_init((void *)TIMER0_BASE_ADDR,sizeof(TIMER_Obj));
      obj->timerHandle[1] = TIMER_init((void *)TIMER1_BASE_ADDR,sizeof(TIMER_Obj));
      obj->timerHandle[2] = TIMER_init((void *)TIMER2_BASE_ADDR,sizeof(TIMER_Obj));
      // initialize drv8353 interface
      obj->drv8353Handle = DRV8353_init(&obj->drv8353,sizeof(obj->drv8353));
      return(handle);
    } // end of HAL_init() function
    void HAL_setParams(HAL_Handle handle,const USER_Params *pUserParams)
      uint_least8_t cnt;
      _iq beta_lp_pu = _IQ(pUserParams->offsetPole_rps/(float_t)pUserParams->ctrlFreq_Hz);
      HAL_setNumCurrentSensors(handle,pUserParams->numCurrentSensors);
      HAL_setNumVoltageSensors(handle,pUserParams->numVoltageSensors);
      for(cnt=0;cnt<HAL_getNumCurrentSensors(handle);cnt++)
          HAL_setOffsetBeta_lp_pu(handle,HAL_SensorType_Current,cnt,beta_lp_pu);
          HAL_setOffsetInitCond(handle,HAL_SensorType_Current,cnt,_IQ(0.0));
          HAL_setOffsetValue(handle,HAL_SensorType_Current,cnt,_IQ(0.0));
      for(cnt=0;cnt<HAL_getNumVoltageSensors(handle);cnt++)
          HAL_setOffsetBeta_lp_pu(handle,HAL_SensorType_Voltage,cnt,beta_lp_pu);
          HAL_setOffsetInitCond(handle,HAL_SensorType_Voltage,cnt,_IQ(0.0));
          HAL_setOffsetValue(handle,HAL_SensorType_Voltage,cnt,_IQ(0.0));
      // disable global interrupts
      // disable cpu interrupts
      CPU_disableInts(obj->cpuHandle);
      // clear cpu interrupt flags
      CPU_clearIntFlags(obj->cpuHandle);
      // setup the clocks
      HAL_setupClks(handle);
      // Setup the PLL
      HAL_setupPll(handle,PLL_ClkFreq_60_MHz);
      // setup the PIE
      HAL_setupPie(handle);
      // run the device calibration
      HAL_cal(handle);
      // setup the peripheral clocks
      HAL_setupPeripheralClks(handle);
      // setup the GPIOs
      HAL_setupGpios(handle);
      // setup the flash
      HAL_setupFlash(handle);
      // setup the ADCs
      HAL_setupAdcs(handle);
      // setup the PWMs
      HAL_setupPwms(handle,
                    (float_t)pUserParams->systemFreq_MHz,
                    pUserParams->pwmPeriod_usec,
                    USER_NUM_PWM_TICKS_PER_ISR_TICK);
    #ifdef DRV8353_SPI
      // setup the spiA
      if(gDeviceVariant)
    	  HAL_setupSpiA(handle);
    #endif
      // setup the timers
      HAL_setupTimers(handle,
                      (float_t)pUserParams->systemFreq_MHz);
      // setup the drv8353 interface
      HAL_setupGate(handle);
      // set the default current bias
       uint_least8_t cnt;
       _iq bias = _IQ12mpy(ADC_dataBias,_IQ(pUserParams->current_sf));
           HAL_setBias(handle,HAL_SensorType_Current,cnt,bias);
      //  set the current scale factor
       _iq current_sf = _IQ(pUserParams->current_sf);
      HAL_setCurrentScaleFactor(handle,current_sf);
      // set the default voltage bias
       uint_least8_t cnt;
       _iq bias = _IQ(0.0);
           HAL_setBias(handle,HAL_SensorType_Voltage,cnt,bias);
      //  set the voltage scale factor
       _iq voltage_sf = _IQ(pUserParams->voltage_sf);
      HAL_setVoltageScaleFactor(handle,voltage_sf);
     return;
    } // end of HAL_setParams() function
    void HAL_setupAdcs(HAL_Handle handle)
      // disable the ADCs
      // enable the ADCs
      // set the ADC interrupt pulse generation to prior
      ADC_setIntPulseGenMode(obj->adcHandle,ADC_IntPulseGenMode_Prior);
      // set the temperature sensor source to external
      ADC_setTempSensorSrc(obj->adcHandle,ADC_TempSensorSrc_Ext);
      // configure the interrupt sources
      ADC_disableInt(obj->adcHandle,ADC_IntNumber_1);
      ADC_setIntMode(obj->adcHandle,ADC_IntNumber_1,ADC_IntMode_ClearFlag);
      ADC_setIntSrc(obj->adcHandle,ADC_IntNumber_1,ADC_IntSrc_EOC7);
      //configure the SOCs for boostxldrv8353
      // sample the first sample twice due to errata sprz342f
      // ISEN_A
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,ADC_SocChanNumber_B3);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_0,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ADC_SocSampleDelay_9_cycles);
      // ISEN_A
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,ADC_SocChanNumber_B3);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_1,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ADC_SocSampleDelay_9_cycles);
      // ISEN_B
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,ADC_SocChanNumber_B1);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_2,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ADC_SocSampleDelay_9_cycles);
      // ISEN_C
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,ADC_SocChanNumber_A0);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_3,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ADC_SocSampleDelay_9_cycles);
      // VSEN_A
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,ADC_SocChanNumber_A7);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_4,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ADC_SocSampleDelay_9_cycles);
      // VSEN_B
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,ADC_SocChanNumber_A3);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_5,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ADC_SocSampleDelay_9_cycles);
      // VSEN_C
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,ADC_SocChanNumber_A1);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_6,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ADC_SocSampleDelay_9_cycles);
      // V_PVDD
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,ADC_SocChanNumber_A6);
      ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_7,ADC_SocTrigSrc_EPWM1_ADCSOCA);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ADC_SocSampleDelay_16_cycles);
      // V_DeviceID
      // Potentiometer // Configure it so that ADCINT1 will trigger a potentiometer conversion
      ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_8,ADC_SocChanNumber_B4);
      ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_8,ADC_SocSampleDelay_9_cycles);
      return;
    } // end of HAL_setupAdcs() function
    void HAL_setupClks(HAL_Handle handle)
      // enable internal oscillator 1
      CLK_enableOsc1(obj->clkHandle);
      // set the oscillator source
      CLK_setOscSrc(obj->clkHandle,CLK_OscSrc_Internal);
      // disable the external clock in
      CLK_disableClkIn(obj->clkHandle);
      // disable the crystal oscillator
      CLK_disableCrystalOsc(obj->clkHandle);
      // disable oscillator 2
      CLK_disableOsc2(obj->clkHandle);
      // set the low speed clock prescaler
    //  CLK_setLowSpdPreScaler(obj->clkHandle,CLK_LowSpdPreScaler_SysClkOut_by_4);
      CLK_setLowSpdPreScaler(obj->clkHandle,CLK_LowSpdPreScaler_SysClkOut_by_2);
      // set the clock out prescaler
      CLK_setClkOutPreScaler(obj->clkHandle,CLK_ClkOutPreScaler_SysClkOut_by_1);
      return;
    } // end of HAL_setupClks() function
    void HAL_setupFlash(HAL_Handle handle)
      FLASH_enablePipelineMode(obj->flashHandle);
      FLASH_setNumPagedReadWaitStates(obj->flashHandle,FLASH_NumPagedWaitStates_2);
      FLASH_setNumRandomReadWaitStates(obj->flashHandle,FLASH_NumRandomWaitStates_2);
      FLASH_setOtpWaitStates(obj->flashHandle,FLASH_NumOtpWaitStates_3);
      FLASH_setStandbyWaitCount(obj->flashHandle,FLASH_STANDBY_WAIT_COUNT_DEFAULT);
      FLASH_setActiveWaitCount(obj->flashHandle,FLASH_ACTIVE_WAIT_COUNT_DEFAULT);
      return;
    } // HAL_setupFlash() function
    void HAL_setupGate(HAL_Handle handle)
    #ifdef DRV8353_SPI
      if(gDeviceVariant)
         DRV8353_setSpiHandle(obj->drv8353Handle,obj->spiAHandle);
    #endif
      DRV8353_setGpioHandle(obj->drv8353Handle,obj->gpioHandle);
      DRV8353_setGpioNumber(obj->drv8353Handle,GPIO_Number_34);		// Enable Gate of DRV8353
    } // HAL_setupGate() function
    void HAL_setupGpios(HAL_Handle handle)
      // PWMA_H
      GPIO_setMode(obj->gpioHandle,GPIO_Number_0,GPIO_0_Mode_EPWM1A);
      // PWMA_L
      GPIO_setMode(obj->gpioHandle,GPIO_Number_1,GPIO_1_Mode_EPWM1B);
      // PWMB_H
      GPIO_setMode(obj->gpioHandle,GPIO_Number_2,GPIO_2_Mode_EPWM2A);
      // PWMB_L
      GPIO_setMode(obj->gpioHandle,GPIO_Number_3,GPIO_3_Mode_EPWM2B);
      // PWMC_H
      GPIO_setMode(obj->gpioHandle,GPIO_Number_4,GPIO_4_Mode_EPWM3A);
      // PWMC_L
      GPIO_setMode(obj->gpioHandle,GPIO_Number_5,GPIO_5_Mode_EPWM3B);
      // EN_GATE
      GPIO_setMode(obj->gpioHandle,GPIO_Number_6,GPIO_6_Mode_GeneralPurpose);
    #ifdef DRV8353_SPI
      if(gDeviceVariant)
    	  // DRV8353 SCS/GAIN
    	  GPIO_setMode(obj->gpioHandle,GPIO_Number_7,GPIO_7_Mode_GeneralPurpose);
    	  GPIO_setHigh(obj->gpioHandle,GPIO_Number_7);
    	  GPIO_setDirection(obj->gpioHandle,GPIO_Number_7,GPIO_Direction_Output);
    #endif
      // No Connection
      // To Read the Push Button SW3 to allow Motor to Run or Stop
      GPIO_setMode(obj->gpioHandle,GPIO_Number_12,GPIO_12_Mode_GeneralPurpose);
      GPIO_setDirection(obj->gpioHandle,GPIO_Number_12,GPIO_Direction_Input);
    #ifdef DRV8353_SPI
      if(gDeviceVariant)
    	  // SPI_SDI if JP4 is soldered, No Connection if JP4 is not soldered
    	  GPIO_setMode(obj->gpioHandle,GPIO_Number_16,GPIO_16_Mode_SPISIMOA);
    	  // SPI_SDO if JP6 is soldered, No Connection if JP6 is not soldered
    	  GPIO_setMode(obj->gpioHandle,GPIO_Number_17,GPIO_17_Mode_SPISOMIA);
    	  GPIO_setPullUp(obj->gpioHandle, GPIO_Number_17, GPIO_PullUp_Disable);
    	  // SPI_CLK
    	  GPIO_setMode(obj->gpioHandle,GPIO_Number_18,GPIO_18_Mode_SPICLKA);
    	  // SPI_SCS
    	  GPIO_setMode(obj->gpioHandle,GPIO_Number_19,GPIO_19_Mode_GeneralPurpose);
      else // Hardware Interface
    #endif
      // MODE
      GPIO_setMode(obj->gpioHandle,GPIO_Number_16,GPIO_16_Mode_GeneralPurpose);
      // LED
      GPIO_setMode(obj->gpioHandle,GPIO_Number_17,GPIO_17_Mode_GeneralPurpose);
     // GPIO_setPullUp(obj->gpioHandle, GPIO_Number_17, GPIO_PullUp_Disable);
      // nFAULT
      GPIO_setMode(obj->gpioHandle,GPIO_Number_28,GPIO_28_Mode_GeneralPurpose);
      // No connection (TX)
      GPIO_setMode(obj->gpioHandle,GPIO_Number_29,GPIO_29_Mode_GeneralPurpose);
      // SPI_SDI if JP5 is soldered, No Connection if JP5 is not soldered
      GPIO_setMode(obj->gpioHandle,GPIO_Number_32,GPIO_32_Mode_GeneralPurpose);
      // SPI_SDO if JP7 is soldered, No Connection if JP7 is not soldered
      GPIO_setMode(obj->gpioHandle,GPIO_Number_33,GPIO_33_Mode_GeneralPurpose);
      // DRV8353 Enable Gate
      GPIO_setMode(obj->gpioHandle,GPIO_Number_34,GPIO_34_Mode_GeneralPurpose);
      GPIO_setLow(obj->gpioHandle,GPIO_Number_34);
      GPIO_setDirection(obj->gpioHandle,GPIO_Number_34,GPIO_Direction_Output);
      // JTAG
      GPIO_setMode(obj->gpioHandle,GPIO_Number_35,GPIO_35_Mode_JTAG_TDI);
      GPIO_setMode(obj->gpioHandle,GPIO_Number_36,GPIO_36_Mode_JTAG_TMS);
      GPIO_setMode(obj->gpioHandle,GPIO_Number_37,GPIO_37_Mode_JTAG_TDO);
      GPIO_setMode(obj->gpioHandle,GPIO_Number_38,GPIO_38_Mode_JTAG_TCK);
      return;
    }  // end of HAL_setupGpios() function
    void HAL_setupLaunchPadGpio0and1(HAL_Handle handle)
      // GPIO 0 (LED 2 on the LaunchPad)
      // Since the LaunchPad uses the same GPIO pins for LEDs as PWM pins,
      // the GPIO 0 and 1 are setup outside of the HAL file.
      GPIO_setMode(obj->gpioHandle,GPIO_Number_0,GPIO_0_Mode_GeneralPurpose);
      GPIO_setLow(obj->gpioHandle,GPIO_Number_0);
      GPIO_setDirection(obj->gpioHandle,GPIO_Number_0,GPIO_Direction_Output);
      // GPIO 1 (LED 4 on the LaunchPad)
      // the GPIO 0 and 1 are setup outside of the HAL file.  GPIO 1 will be
      // kept low so that there is no possibility of shoot-through conduction
      // with the high side switch that is controlled by GPIO0.
      GPIO_setMode(obj->gpioHandle,GPIO_Number_1,GPIO_1_Mode_GeneralPurpose);
      GPIO_setLow(obj->gpioHandle,GPIO_Number_1);
      GPIO_setDirection(obj->gpioHandle,GPIO_Number_1,GPIO_Direction_Output);
      return;
    void HAL_setupPie(HAL_Handle handle)
      PIE_disable(obj->pieHandle);
      PIE_disableAllInts(obj->pieHandle);
      PIE_clearAllInts(obj->pieHandle);
      PIE_clearAllFlags(obj->pieHandle);
      PIE_setDefaultIntVectorTable(obj->pieHandle);
      PIE_enable(obj->pieHandle);
      return;
    } // end of HAL_setupPie() function
    void HAL_setupPeripheralClks(HAL_Handle handle)
      CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_1);
      CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_2);
      CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_3);
      CLK_enableEcap1Clock(obj->clkHandle);
      CLK_enablePwmClock(obj->clkHandle,PWM_Number_1);
      CLK_enablePwmClock(obj->clkHandle,PWM_Number_2);
      CLK_enablePwmClock(obj->clkHandle,PWM_Number_3);
      CLK_enablePwmClock(obj->clkHandle,PWM_Number_4);
      CLK_disableHrPwmClock(obj->clkHandle);
      CLK_disableI2cClock(obj->clkHandle);
      CLK_enableSciaClock(obj->clkHandle);
    #ifdef DRV8353_SPI
      if(gDeviceVariant)
    	  CLK_enableSpiaClock(obj->clkHandle);
    #endif
      CLK_enableTbClockSync(obj->clkHandle);
      return;
    } // end of HAL_setupPeripheralClks() function
    void HAL_setupPll(HAL_Handle handle,const PLL_ClkFreq_e clkFreq)
      // make sure PLL is not running in limp mode
      if(PLL_getClkStatus(obj->pllHandle) != PLL_ClkStatus_Normal)
          // reset the clock detect
          PLL_resetClkDetect(obj->pllHandle);
          asm("        ESTOP0");
      // Divide Select must be ClkIn/4 before the clock rate can be changed
      if(PLL_getDivideSelect(obj->pllHandle) != PLL_DivideSelect_ClkIn_by_4)
          PLL_setDivideSelect(obj->pllHandle,PLL_DivideSelect_ClkIn_by_4);
      if(PLL_getClkFreq(obj->pllHandle) != clkFreq)
          // disable the clock detect
          PLL_disableClkDetect(obj->pllHandle);
          // set the clock rate
          PLL_setClkFreq(obj->pllHandle,clkFreq);
      // wait until locked
      while(PLL_getLockStatus(obj->pllHandle) != PLL_LockStatus_Done) {}
      // enable the clock detect
      PLL_enableClkDetect(obj->pllHandle);
      // set divide select to ClkIn/2 to get desired clock rate
      // NOTE: clock must be locked before setting this register
      PLL_setDivideSelect(obj->pllHandle,PLL_DivideSelect_ClkIn_by_2);
      return;
    } // end of HAL_setupPll() function
    void HAL_setupPwms(HAL_Handle handle,
                       const float_t systemFreq_MHz,
                       const float_t pwmPeriod_usec,
                       const uint_least16_t numPwmTicksPerIsrTick)
      uint16_t   halfPeriod_cycles = (uint16_t)(systemFreq_MHz*pwmPeriod_usec) >> 1;
      uint_least8_t    cnt;
      // turns off the outputs of the EPWM peripherals which will put the power switches
      // into a high impedance state.
      PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_1]);
      PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_2]);
      PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_3]);
      // first step to synchronize the pwms
      CLK_disableTbClockSync(obj->clkHandle);
          // setup the Time-Base Control Register (TBCTL)
          PWM_setCounterMode(obj->pwmHandle[cnt],PWM_CounterMode_UpDown);
          PWM_disableCounterLoad(obj->pwmHandle[cnt]);
          PWM_setPeriodLoad(obj->pwmHandle[cnt],PWM_PeriodLoad_Immediate);
          PWM_setSyncMode(obj->pwmHandle[cnt],PWM_SyncMode_EPWMxSYNC);
          PWM_setHighSpeedClkDiv(obj->pwmHandle[cnt],PWM_HspClkDiv_by_1);
          PWM_setClkDiv(obj->pwmHandle[cnt],PWM_ClkDiv_by_1);
          PWM_setPhaseDir(obj->pwmHandle[cnt],PWM_PhaseDir_CountUp);
          PWM_setRunMode(obj->pwmHandle[cnt],PWM_RunMode_FreeRun);
          // setup the Timer-Based Phase Register (TBPHS)
          PWM_setPhase(obj->pwmHandle[cnt],0);
          // setup the Time-Base Counter Register (TBCTR)
          PWM_setCount(obj->pwmHandle[cnt],0);
          // setup the Time-Base Period Register (TBPRD)
          // set to zero initially
          PWM_setPeriod(obj->pwmHandle[cnt],0);
          // setup the Counter-Compare Control Register (CMPCTL)
          PWM_setLoadMode_CmpA(obj->pwmHandle[cnt],PWM_LoadMode_Zero);
          PWM_setLoadMode_CmpB(obj->pwmHandle[cnt],PWM_LoadMode_Zero);
          PWM_setShadowMode_CmpA(obj->pwmHandle[cnt],PWM_ShadowMode_Shadow);
          PWM_setShadowMode_CmpB(obj->pwmHandle[cnt],PWM_ShadowMode_Immediate);
          // setup the Action-Qualifier Output A Register (AQCTLA)
          PWM_setActionQual_CntUp_CmpA_PwmA(obj->pwmHandle[cnt],PWM_ActionQual_Set);
          PWM_setActionQual_CntDown_CmpA_PwmA(obj->pwmHandle[cnt],PWM_ActionQual_Clear);
          // setup the Dead-Band Generator Control Register (DBCTL)
          PWM_setDeadBandOutputMode(obj->pwmHandle[cnt],PWM_DeadBandOutputMode_EPWMxA_Rising_EPWMxB_Falling);
          PWM_setDeadBandPolarity(obj->pwmHandle[cnt],PWM_DeadBandPolarity_EPWMxB_Inverted);
          // setup the Dead-Band Rising Edge Delay Register (DBRED)
          PWM_setDeadBandRisingEdgeDelay(obj->pwmHandle[cnt],HAL_PWM_DBRED_CNT);
          // setup the Dead-Band Falling Edge Delay Register (DBFED)
          PWM_setDeadBandFallingEdgeDelay(obj->pwmHandle[cnt],HAL_PWM_DBFED_CNT);
          // setup the PWM-Chopper Control Register (PCCTL)
          PWM_disableChopping(obj->pwmHandle[cnt]);
          // setup the Trip Zone Select Register (TZSEL)
          PWM_disableTripZones(obj->pwmHandle[cnt]);
      // setup the Event Trigger Selection Register (ETSEL)
      PWM_disableInt(obj->pwmHandle[PWM_Number_1]);
      PWM_setSocAPulseSrc(obj->pwmHandle[PWM_Number_1],PWM_SocPulseSrc_CounterEqualZero);
      PWM_enableSocAPulse(obj->pwmHandle[PWM_Number_1]);
      // setup the Event Trigger Prescale Register (ETPS)
      if(numPwmTicksPerIsrTick == 3)
          PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_ThirdEvent);
          PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_ThirdEvent);
      else if(numPwmTicksPerIsrTick == 2)
          PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_SecondEvent);
          PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_SecondEvent);
      else
          PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_FirstEvent);
          PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_FirstEvent);
      // setup the Event Trigger Clear Register (ETCLR)
      PWM_clearIntFlag(obj->pwmHandle[PWM_Number_1]);
      PWM_clearSocAFlag(obj->pwmHandle[PWM_Number_1]);
      // since the PWM is configured as an up/down counter, the period register is set to one-half
      // of the desired PWM period
      PWM_setPeriod(obj->pwmHandle[PWM_Number_1],halfPeriod_cycles);
      PWM_setPeriod(obj->pwmHandle[PWM_Number_2],halfPeriod_cycles);
      PWM_setPeriod(obj->pwmHandle[PWM_Number_3],halfPeriod_cycles);
      // last step to synchronize the pwms
      return;
    }  // end of HAL_setupPwms() function
    #ifdef DRV8353_SPI
    void HAL_setupSpiA(HAL_Handle handle)
      SPI_reset(obj->spiAHandle);
      SPI_setMode(obj->spiAHandle,SPI_Mode_Master);
      SPI_setClkPolarity(obj->spiAHandle,SPI_ClkPolarity_OutputRisingEdge_InputFallingEdge);
      SPI_enableTx(obj->spiAHandle);
      SPI_enableTxFifoEnh(obj->spiAHandle);
      SPI_enableTxFifo(obj->spiAHandle);
      SPI_setTxDelay(obj->spiAHandle,0x0010);
      SPI_setBaudRate(obj->spiAHandle,(SPI_BaudRate_e)(0x0010));
      SPI_setCharLength(obj->spiAHandle,SPI_CharLength_16_Bits);
      SPI_setSuspend(obj->spiAHandle,SPI_TxSuspend_free);
      SPI_enable(obj->spiAHandle);
      return;
    }  // end of HAL_setupSpiA() function
    #endif
    void HAL_setupTimers(HAL_Handle handle,const float_t systemFreq_MHz)
      uint32_t  timerPeriod_0p5ms = (uint32_t)(systemFreq_MHz * (float_t)500.0) - 1;
      uint32_t  timerPeriod_10ms = (uint32_t)(systemFreq_MHz * (float_t)10000.0) - 1;
      // use timer 0 for frequency diagnostics
      TIMER_setDecimationFactor(obj->timerHandle[0],0);
      TIMER_setEmulationMode(obj->timerHandle[0],TIMER_EmulationMode_RunFree);
      TIMER_setPeriod(obj->timerHandle[0],timerPeriod_0p5ms);
      TIMER_setPreScaler(obj->timerHandle[0],0);
      // use timer 1 for CPU usage diagnostics
      TIMER_setDecimationFactor(obj->timerHandle[1],0);
      TIMER_setEmulationMode(obj->timerHandle[1],TIMER_EmulationMode_RunFree);
      TIMER_setPeriod(obj->timerHandle[1],timerPeriod_10ms);
      TIMER_setPreScaler(obj->timerHandle[1],0);
      // use timer 2 for CPU time diagnostics
      TIMER_setDecimationFactor(obj->timerHandle[2],0);
      TIMER_setEmulationMode(obj->timerHandle[2],TIMER_EmulationMode_RunFree);
      TIMER_setPeriod(obj->timerHandle[2],0xFFFFFFFF);
      TIMER_setPreScaler(obj->timerHandle[2],0);
      return;
    }  // end of HAL_setupTimers() function
    #ifdef DRV8353_SPI
    void HAL_writeDrvData(HAL_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars)
      DRV8353_writeData(obj->drv8353Handle,Spi_8353_Vars);
      return;
    }  // end of HAL_writeDrvData() function
    void HAL_readDrvData(HAL_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars)
      DRV8353_readData(obj->drv8353Handle,Spi_8353_Vars);
      return;
    }  // end of HAL_readDrvData() function
    void HAL_setupDrvSpi(HAL_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars)
      DRV8353_setupSpi(obj->drv8353Handle,Spi_8353_Vars);
      return;
    }  // end of HAL_setupDrvSpi() function
    #endif
    void HAL_setDacParameters(HAL_Handle handle, HAL_DacData_t *pDacData)
    	pDacData->PeriodMax = PWMDAC_getPeriod(obj->pwmDacHandle[PWMDAC_Number_1]);
    	pDacData->offset[0] = _IQ(0.5);
    	pDacData->offset[1] = _IQ(0.5);
    	pDacData->offset[2] = _IQ(0.0);
    	pDacData->offset[3] = _IQ(0.0);
    	pDacData->gain[0] = _IQ(1.0);
    	pDacData->gain[1] = _IQ(1.0);
    	pDacData->gain[2] = _IQ(1.0);
    	pDacData->gain[3] = _IQ(1.0);
    	return;
    }	//end of HAL_setDacParameters() function
    // end of file
  • With the update of the previous reply,  We tried to use the updated hal file for the drv8353rs EVM board. We found that the GPIO 12 pin is defined for Hall B. Hence, we would like to know, How to use the push button available in the F28027F microcontroller which is also connected to GPIO 12. I have enclosed the schematic file of the Microcontroller EVM Board and the new Hall.c file.
    In this case, Is it possible to connect an external switch with the controller, and how can it be connected since all the gpio pins available are defined for a function? Kindly let us know.
    0638.hal.c
     * are met:
     * --/COPYRIGHT--*/
    // the includes
    // drivers
    // modules
    // platforms
    #include "hal.h"
    #include "user.h"
    #ifdef FLASH
    #endif
    // the defines
    // the globals
    #ifdef F2802xF
    #endif
    HAL_Obj hal;
    // the functions
      (*Device_cal)();
      return;
      // disable the ADCs
      // enable the ADCs
      // enable ADCINT1
      return;
        return;
        return;
      if(fine < 0)
      else
      if(coarse < 0)
      else
          regValue |= coarse;
      return regValue;
      // disable the ADCs
      // enable the ADCs
      return;
      return;
      uint32_t Sum;
          index+=16;
      return(Mean);
      return;
      return;
      return;
      return;
      return;
      return;
      return;
      uint_least8_t cnt;
      return;
      uint_least8_t cnt;
      HAL_Handle handle;
      HAL_Obj *obj;
      // disable watchdog
      return(handle);
    //TODO: HAL_setParams
      uint_least8_t cnt;
      // setup the clocks
      // Setup the PLL
      // setup the PIE
      HAL_cal(handle);
      // setup the GPIOs
      // setup the flash
      // setup the ADCs
      // setup the PWMs
      // setup the spiA
      // setup the timers
       uint_least8_t cnt;
       uint_least8_t cnt;
     return;
      // disable the ADCs
      // enable the ADCs
      //configure the SOCs for drv8353evm
      // ISEN_A
      // ISEN_A
      // ISEN_B
      // ISEN_C
      // VSEN_A
      // VSEN_B
      // VSEN_C
      // V_PVDD
      // V_DeviceID
      return;
      return;
      return;
      DRV8353_setSpiHandle(obj->drv8353Handle, obj->spiAHandle);
      DRV8353_setGpioHandle(obj->drv8353Handle, obj->gpioHandle);
      DRV8353_setGpioNumber(obj->drv8353Handle, GPIO_Number_34);		// Enable Gate of DRV8353
      return;
      // PWMA_H
      // PWMA_L
      // PWMB_H
      // PWMB_L
      // PWMC_H
      // PWMC_L
      // HALL_C
      // DRV8353 SCS/GAIN
      // HALL_B
      // SPI_CLK
      // HALL_A->ECAP1
      // SCI_RX
      GPIO_setMode(obj->gpioHandle,GPIO_Number_28,GPIO_28_Mode_SCIRXDA);
      // SCI_TX
      GPIO_setMode(obj->gpioHandle,GPIO_Number_29,GPIO_29_Mode_SCITXDA);
      // N/A
      GPIO_setLow(obj->gpioHandle,GPIO_Number_32);
      GPIO_setDirection(obj->gpioHandle,GPIO_Number_32,GPIO_Direction_Output);
      // DRV8353_LED
      GPIO_setHigh(obj->gpioHandle,GPIO_Number_33);
      GPIO_setDirection(obj->gpioHandle,GPIO_Number_33,GPIO_Direction_Output);
      GPIO_setLow(obj->gpioHandle,GPIO_Number_34);      // Disable DRV83533 First
      // JTAG
      return;
      return;
      return;
          asm("        ESTOP0");
      return;
      uint_least8_t    cnt;
      else
      return;
      return;
      return;
      return;
      return;
      return;
    	return;
    // end of file
    3343.MD017A_Sch.pdf
  • You need to use the other spare GPIOs if the GPIO is used for hall sensor input. You can use GPIO28 and GPIO29 if you don't use these two GPIOs for SCI.
  • Thank you Yanming for your immediate responses. This solved our issue. We used GPIO 28 for the external switch and could able to control the motor using the switch.
