Other Parts Discussed in Thread: LAUNCHXL-F280025C, BOOSTXL-BUCKCONV,
Hi Expert,
I try to modify the example code based on F28004x for BOOSTXL-BUCKCONV (in the TIDM-DC-DC-BUCK CONVERTER) to make it run on my LAUNCHXL-F280025C. So I have an issue when I load the program
(message :
RAM initialization done
C28xx_CPU1: GEL Output:
Memory Map Initialization Complete
C28xx_CPU1: GEL Output: ... DCSM Initialization Start ...
C28xx_CPU1: GEL Output: ... DCSM Initialization Done ...
C28xx_CPU1: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.)
I have replace the target on targetConfigs file, I configure correctly GPIO (this is not the problem), I include F28002x\driverlib and it doesn't work anyway.
Can you help me please ? What I forget ?
You can see others screen shot for my project :
Damien
