CODECOMPOSER: Is there any way to export software/app/library versions as report?
Part Number: CODECOMPOSER
Other Parts Discussed in Thread: C2000WARE, CCSTUDIO
Hi all!
As mentioned in the caption I want to note the versions of related softwares, apps, libraires etc. before I start to develope a project. Main things are compiler and library versions actually.
Thanks in advance.
cheers,
    Please see the below documentation for the "inspect" command:
    https://software-dl.ti.com/ccs/esd/documents/ccs_projects-command-line.html#com-ti-ccstudio-apps-inspect
    The command can be used to get infromation at the project, workspace, and product level.
    ki
  • Hi Ki!
    Sorry but I am not familiar with CLI tools. Can I do it on the IDE? Or is there a manual to to understand command line interface of the CCS? Is there a built in console in CCS?
    cheers,
  • It is command line only from a system terminal. Please see the beginning of the article that i referenced earlier for more details on how to use it:
    For example, I ran the following command on one for my C2000Ware projects from a DOS command window:
    c:\ti\ccs1100\ccs\eclipse\eclipsec -noSplash -data c:\ti\workspaces\1100 -application com.ti.ccstudio.apps.inspect -ccs.projects sci_ex1_echoback > project_inspect.txt
    It generated the below output in the attached text file:
    Project: sci_ex1_echoback [C:/ti/workspaces/1100/sci_ex1_echoback] [origin:"C:\ti\C2000Ware_3_04_00_00_Software\device_support\f28004x\examples\sci\CCS\sci_ex1_echoback.projectspec"]
    	References: <none>
    	Settings:
    		Configuration: CPU1_RAM [active]
    			 build artifact: ${ProjName}.out
    			    output type: executable
    			         device: TMS320C28XX.TMS320F280049C [TMS320F280049C]
    			        variant: C28XX [C2000]
    			     endianness: little
    			   tool version: TI v18.9.0.STS
    			  output format: COFF
    			linker cmd-file:
    			    rts-library: libc.a
    			     references: <none>
    			 pre-build step: <none>
    			post-build step: <none>
    			build-variables: <none>
    			 build settings:
    				C2000 Compiler:
    					  command: "${CG_TOOL_CL}"
    					  pattern: ${command} ${flags} ${inputs}
    					    flags: -v28 -ml -mt --cla_support=cla2 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu0 -Ooff --include_path="C:/ti/workspaces/1100/sci_ex1_echoback" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include" --include_path="C:/ti/ti-cgt-c2000_18.9.0.STS/include" --define=CPU1 --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi
    				C2000 Linker:
    					  pattern: ${command} ${flags} ${output_flag} ${output} ${inputs}
    					    flags: -z -m"sci_ex1_echoback.map" --stack_size=0x100 --warn_sections -i"C:/ti/ti-cgt-c2000_18.9.0.STS/lib" -i"C:/ti/ti-cgt-c2000_18.9.0.STS/include" --reread_libs --diag_wrap=off --display_error_number --xml_link_info="sci_ex1_echoback_linkInfo.xml" --entry_point=code_start --rom_model
    		Configuration: CPU1_FLASH
    			     endianness: little
    			  output format: COFF
    			linker cmd-file:
    			    rts-library: libc.a
    			     references: <none>
    			 build settings:
    				C2000 Compiler:
    					    flags: -v28 -ml -mt --cla_support=cla2 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu0 -Ooff --include_path="C:/ti/workspaces/1100/sci_ex1_echoback" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include" --include_path="C:/ti/ti-cgt-c2000_18.9.0.STS/include" --define=CPU1 --define=_FLASH --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi
    				C2000 Linker:
    	Resources:
    		28004x_generic_flash_lnk.cmd
    		28004x_generic_ram_lnk.cmd
    		f28004x_codestartbranch.asm
    		f28004x_defaultisr.c
    		f28004x_globalvariabledefs.c
    		f28004x_gpio.c
    		f28004x_headers_nonbios.cmd
    		f28004x_piectrl.c
    		f28004x_pievect.c
    		f28004x_sysctrl.c
    		f28004x_usdelay.asm
    		sci_ex1_echoback.c
    	External resource dependencies:
    			Compiler:
    				specified version: TI v18.9.0.STS
    				effective version: TI v18.9.0.STS [C:/ti/ti-cgt-c2000_18.9.0.STS]
    			Products:
    				product: c2000ware_software_package [C2000Ware]
    				specified version: 3.4.0.00
    				effective version: 3.4.0.00 [C:/ti/C2000Ware_3_04_00_00_Software]
    			Build flags:
    				C:/ti/ti-cgt-c2000_18.9.0.STS/lib/libc.a
    			Source lookup-path: <none>
    			Source dependencies:
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/F28x_Project.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_adc_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_cla_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_cla_typedefs.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_cputimervars.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_defaultisr.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_dma_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_epwm_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_examples.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_globalprototypes.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_gpio_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_pie_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include/f28004x_sysctrl_defines.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_adc.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_analogsubsys.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_can.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_cla.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_cla_prom_crc32.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_clb.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_clbxbar.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_cmpss.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_cputimer.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_dac.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_dcc.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_dcsm.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_device.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_dma.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_ecap.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_epwm.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_epwm_xbar.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_eqep.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_erad.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_flash.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_fsi.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_gpio.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_i2c.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_input_xbar.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_lin.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_memconfig.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_nmiintrupt.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_output_xbar.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_pga.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_piectrl.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_pievect.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_pmbus.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_sci.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_sdfm.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_spi.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_sysctrl.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_xbar.h
    				C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include/f28004x_xint.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/_stdint40.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/_ti_config.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/assert.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/linkage.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/stdarg.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/stdbool.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/stddef.h
    				C:/ti/ti-cgt-c2000_18.9.0.STS/include/stdint.h
    			Compiler:
    			Products:
    			Build flags:
    		Linked resources: <none>
    	Variables:
    			=C: = c:\ti\workspaces\1100
    			=D: = D:\
    			=E: = E:\
    			=ExitCode = 00000000
    			=F: = F:\
    			=O: = O:\
    			=T: = T:\
    			=V: = V:\
    			active_core_build_dir = null
    			ALLUSERSPROFILE = C:\ProgramData
    			APPDATA = C:\Users\a0389327\AppData\Roaming
    			ArchType = x86_64
    			AWE_DIR = C:\Program Files (x86)\Khrona LLC\Awesomium SDK\1.6.6\
    			BIOS_CG_ROOT = C:\ti\bios_6_83_00_18
    			BIOS_INSTALL_DIR = C:\CCStudio_v3.3PLA\bios_5_33_05
    			build_artifact = null
    			build_files = null
    			build_project = null
    			build_type = none
    			build_var = null
    			BuildArtifactFileBaseName = ${ProjName}
    			BuildArtifactFileExt = out
    			BuildArtifactFileName = ${ProjName}.out
    			BuildArtifactFilePath = C:/ti/workspaces/1100/sci_ex1_echoback/CPU1_RAM/sci_ex1_echoback.out
    			BuildArtifactFilePrefix =
    			BuildDirectory = C:/ti/workspaces/1100/sci_ex1_echoback/CPU1_RAM
    			BuilderVersion = 0.0.4
    			C2000_CG_ROOT = C:/ti/ti-cgt-c2000_18.9.0.STS
    			C2000WARE_COMMON_INCLUDE = ${COM_TI_C2000WARE_SOFTWARE_PACKAGE_INSTALL_DIR}/device_support/f28004x/common/include
    			C2000WARE_HEADERS_INCLUDE = ${COM_TI_C2000WARE_SOFTWARE_PACKAGE_INSTALL_DIR}/device_support/f28004x/headers/include
    			CCE_INSTALL_ROOT = C:/ti/ccs1100/ccs
    			ccs_base_root = C:\ti\ccs1100\ccs\ccs_base
    			CCS_BASE_ROOT = C:/ti/ccs1100/ccs/ccs_base
    			ccs_eval_var = null
    			ccs_find_file =
    			CCS_IDE_MODE = desktop
    			CCS_INSTALL_DIR = C:\ti\ccs1100\ccs
    			ccs_install_root = C:\ti\ccs1100\ccs
    			CCS_INSTALL_ROOT = C:/ti/ccs1100/ccs
    			CCS_JAVA_HOME = c:\ti\ccs1100\ccs\eclipse\jre
    			ccs_product_root =
    			CCS_PROJECT_DIR = C:\ti\workspaces\1100\sci_ex1_echoback
    			CCS_PROJECT_TEMP_DIR = C:\ti\workspaces\1100\.metadata\.plugins\org.eclipse.core.resources\.projects\sci_ex1_echoback\.temp
    			CCS_UTILS_DIR = C:/ti/ccs1100/ccs/utils
    			CCS_WORKSPACE_DIR = C:\ti\workspaces\1100
    			CCS_WORKSPACE_TEMP_DIR = C:\ti\workspaces\1100\.metadata\.temp
    			cdt_pathentry_var = null
    			CDTVersion = 7.2.0.202102251239
    			CG_CLEAN_CMD = DEL /F
    			CG_TOOL_AR = C:/ti/ti-cgt-c2000_18.9.0.STS/bin/ar2000
    			CG_TOOL_CL = C:/ti/ti-cgt-c2000_18.9.0.STS/bin/cl2000
    			CG_TOOL_HEX = C:/ti/ti-cgt-c2000_18.9.0.STS/bin/hex2000
    			CG_TOOL_ROOT = C:/ti/ti-cgt-c2000_18.9.0.STS
    			CODEC_ENGINE_CG_ROOT = [${COM_TI_CODEC_ENGINE_CG_ROOT}]
    			COM_TI_C2000WARE_SOFTWARE_PACKAGE_INCLUDE_PATH = []
    			COM_TI_C2000WARE_SOFTWARE_PACKAGE_INSTALL_DIR = C:/ti/C2000Ware_3_04_00_00_Software
    			COM_TI_C2000WARE_SOFTWARE_PACKAGE_LIBRARIES = []
    			COM_TI_C2000WARE_SOFTWARE_PACKAGE_LIBRARY_PATH = []
    			COM_TI_C2000WARE_SOFTWARE_PACKAGE_SYMBOLS = []
    			COM_TI_C2000WARE_SOFTWARE_PACKAGE_SYSCONFIG_MANIFEST = null
    			COM_TI_RTSC_TIRTOSCC13XX_CC26XX_INSTALL_DIR = C:\ti\tirtos_cc13xx_cc26xx_2_20_01_08
    			COM_TI_RTSC_TIRTOSTIVAC_INSTALL_DIR = C:\ti\tirtos_tivac_2_16_00_08
    			CommonProgramFiles = C:\Program Files\Common Files
    			CommonProgramFiles(x86) = C:\Program Files (x86)\Common Files
    			CommonProgramW6432 = C:\Program Files\Common Files
    			COMPILER_FLAGS = -v28 -ml -mt --cla_support=cla2 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu0 -Ooff --include_path="C:/ti/workspaces/1100/sci_ex1_echoback" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include" --include_path="C:/ti/ti-cgt-c2000_18.9.0.STS/include" --define=CPU1 --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi
    			COMPILER_FLAGS__C =
    			COMPILER_FLAGS__CPP =
    			COMPUTERNAME = TGLA0389327X
    			ComSpec = C:\WINDOWS\system32\cmd.exe
    			config_description = null
    			config_name = null
    			ConfigDescription =
    			ConfigName = CPU1_RAM
    			current_date = 20211222_0936
    			CWD = C:\ti\workspaces\1100\sci_ex1_echoback\CPU1_RAM
    			DEVICE = TMS320F280049C
    			DEVMGR_SHOW_DETAILS = 1
    			DEVMGR_SHOW_NONPRESENT_DEVICES = 1
    			DirectoryDelimiter = \
    			DriverData = C:\Windows\System32\Drivers\DriverData
    			eclipse_home = C:\ti\ccs1100\ccs\eclipse\
    			ECLIPSE_HOME = C:/ti/ccs1100/ccs/eclipse/
    			EclipseVersion = 4.19.0.v20210303-1800
    			env_var = null
    			ESDSERVER = dleesd.itg.ti.com
    			FRAMEWORK_COMPONENTS_CG_ROOT = [${COM_TI_FRAMEWORK_COMPONENTS_CG_ROOT}]
    			from_system_xml = null
    			GENERATED_LIBRARIES = $(GEN_CMDS__FLAG)
    			git_branch = null
    			git_dir = null
    			git_repo_relative_path = null
    			git_work_tree = null
    			HOMEDRIVE = C:
    			HOMEPATH = \Users\a0389327
    			HostArchName = amd64
    			HostOsName = Windows 10
    			INHERITED_INCLUDE_PATH = []
    			INHERITED_LIBRARIES = []
    			INHERITED_LIBRARY_PATH = []
    			INHERITED_SYMBOLS = []
    			INHERITED_SYSCONFIG_MANIFESTS = []
    			IPC_CG_ROOT = [${COM_TI_IPC_CG_ROOT}]
    			LINKER_FLAGS = -z -m"sci_ex1_echoback.map" --stack_size=0x100 --warn_sections -i"C:/ti/ti-cgt-c2000_18.9.0.STS/lib" -i"C:/ti/ti-cgt-c2000_18.9.0.STS/include" --reread_libs --diag_wrap=off --display_error_number --xml_link_info="sci_ex1_echoback_linkInfo.xml" --entry_point=code_start --rom_model
    			LOCALAPPDATA = C:\Users\a0389327\AppData\Local
    			LOGONSERVER = \\LEWVADDC08
    			NDK_INSTALL_DIR = [${COM_TI_NDK_INSTALL_DIR}]
    			NIEXTCCOMPILERSUPP = C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\
    			NODE_TOOL = C:/ti/ccs1100/ccs/tools/node/node.exe
    			NUMBER_OF_PROCESSORS = 8
    			OneDrive = C:\Users\a0389327\OneDrive
    			OS = Windows_NT
    			OSAL_CG_ROOT = [${COM_TI_OSAL_CG_ROOT}]
    			OsType = win32
    			PARENT_LOC = C:/ti/workspaces/1100
    			PATH = c:/ti/ccs1100/ccs/eclipse/jre/bin/client;c:/ti/ccs1100/ccs/eclipse/jre/bin;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ti\xdctools_3_32_00_06_core;C:\ProgramData\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\PuTTY\;C:\Strawberry\c\bin;C:\Strawberry\perl\site\bin;C:\Strawberry\perl\bin;C:\Program Files\Git\cmd;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Pandoc\;C:\Program Files\MATLAB\MATLAB Runtime\v92\runtime\win64;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\Webex\Webex\Applications;C:\Program Files\Java\jdk1.8.0_191\bin;C:\Python39;C:\Python39\Scripts;C:\ti\xdctools_3_32_00_06_core;C:\Users\a0389327\AppData\Local\Microsoft\WindowsApps;;C:\Users\a0389327\AppData\Local\Programs\Microsoft VS Code\bin;c:\ti\workspaces\1100;
    			PathDelimiter = ;
    			PATHEXT = [.COM, .EXE, .BAT, .CMD, .VBS, .VBE, .JS, .JSE, .WSF, .WSH, .MSC]
    			PROCESSOR_ARCHITECTURE = AMD64
    			PROCESSOR_IDENTIFIER = Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
    			PROCESSOR_LEVEL = 6
    			PROCESSOR_REVISION = 9e09
    			ProgramData = C:\ProgramData
    			ProjDirPath = C:/ti/workspaces/1100/sci_ex1_echoback
    			PROJECT_BUILD_DIR = C:/ti/workspaces/1100/sci_ex1_echoback/CPU1_RAM
    			PROJECT_LOC = C:/ti/workspaces/1100/sci_ex1_echoback
    			project_ref = null
    			PROJECT_ROOT = C:/ti/workspaces/1100/sci_ex1_echoback
    			ProjName = sci_ex1_echoback
    			PROMPT = $P$G
    			PSModulePath = [C:\Program Files\WindowsPowerShell\Modules, C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules]
    			PSPDRIVERS_INSTALL_DIR = [${COM_TI_PSPDRIVERS_INSTALL_DIR}]
    			PUBLIC = C:\Users\Public
    			PWD = C:\ti\workspaces\1100\sci_ex1_echoback\CPU1_RAM
    			RTDX_CG_ROOT = [${COM_TI_RTDX_CG_ROOT}]
    			selected_resource_loc = null
    			selected_resource_name = null
    			selected_resource_path = null
    			SESSIONNAME = Console
    			SRFPROG2 = C:\Program Files (x86)\Texas Instruments\SmartRF Tools\Flash Programmer 2\bin
    			SYSCONFIG_TOOL = C:/ti/ccs1100/ccs/utils/sysconfig_1.10.0/sysconfig_cli.bat
    			SYSCONFIG_TOOL_ROOT = C:/ti/ccs1100/ccs/utils/sysconfig_1.10.0
    			system = null
    			system_path = null
    			system_property = null
    			SystemDrive = C:
    			SystemRoot = C:\WINDOWS
    			target_config_active = null
    			target_config_active_default = C:\Users\a0389327\ti\CCSTargetConfigurations\NewTargetConfiguration.ccxml
    			target_config_default = C:\Users\a0389327\ti\CCSTargetConfigurations\NewTargetConfiguration.ccxml
    			TARGET_CONTENT_BASE = C:/ti/ccs1100/ccs/ccs_base
    			TargetArchList = [all]
    			TargetOsList = [all]
    			TEMP = C:\Users\a0389327\AppData\Local\Temp
    			TI_MAS_DSPLIB_C64PX_INSTALL_DIR = [${COM_TI_MAS_DSPLIB_C64PX_INSTALL_DIR}]
    			TI_MAS_DSPLIB_C66X_INSTALL_DIR = [${COM_TI_MAS_DSPLIB_C66X_INSTALL_DIR}]
    			TI_MAS_DSPLIB_C674X_INSTALL_DIR = [${COM_TI_MAS_DSPLIB_C674X_INSTALL_DIR}]
    			TI_MATHLIB_C66X_INSTALL_DIR = [${COM_TI_MATHLIB_C66X_INSTALL_DIR}]
    			TI_PDK_INSTALL_DIR = [${COM_TI_PDK_INSTALL_DIR}]
    			TI_PRODUCTS_DIR = C:/ti
    			TI_PRODUCTS_DIR__TIREX = C:/ti
    			TMP = C:\Users\a0389327\AppData\Local\Temp
    			ToolChainVersion = 0.0.4
    			UATDATA = C:\WINDOWS\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77
    			USERDNSDOMAIN = ENT.TI.COM
    			USERDOMAIN = ENT
    			USERDOMAIN_ROAMINGPROFILE = ENT
    			USERNAME = a0389327
    			USERPROFILE = C:\Users\a0389327
    			VBOX_MSI_INSTALL_PATH = C:\Program Files\Oracle\VirtualBox\
    			VXIPNPPATH = C:\Program Files (x86)\IVI Foundation\VISA\
    			VXIPNPPATH64 = C:\Program Files\IVI Foundation\VISA\
    			windir = C:\WINDOWS
    			workspace_loc = C:\ti\workspaces\1100
    			WORKSPACE_LOC = C:/ti/workspaces/1100
    			WorkspaceDirPath = C:\ti\workspaces\1100
    			WROKK = c:\temp
    			XDAIS_CG_ROOT = [${COM_TI_XDAIS_CG_ROOT}]
    			xdc_find =
    			xdc_var =
    			XDCPATH =
    			XDCPLATFORM = null
    			XDCROOT = C:\ti\xdctools_3_32_00_06_core
    			XDCTARGET = null
    			=D: = D:\
    			=E: = E:\
    			=F: = F:\
    			=O: = O:\
    			=T: = T:\
    			=V: = V:\
    			ArchType = x86_64
    			build_files = null
    			build_type = none
    			build_var = null
    			BuildArtifactFilePath = C:/ti/workspaces/1100/sci_ex1_echoback/CPU1_FLASH/sci_ex1_echoback.out
    			BuildDirectory = C:/ti/workspaces/1100/sci_ex1_echoback/CPU1_FLASH
    			ccs_eval_var = null
    			ccs_find_file =
    			ccs_product_root =
    			COMPILER_FLAGS = -v28 -ml -mt --cla_support=cla2 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu0 -Ooff --include_path="C:/ti/workspaces/1100/sci_ex1_echoback" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/common/include" --include_path="C:/ti/C2000Ware_3_04_00_00_Software/device_support/f28004x/headers/include" --include_path="C:/ti/ti-cgt-c2000_18.9.0.STS/include" --define=CPU1 --define=_FLASH --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --abi=coffabi
    			COMPILER_FLAGS__C =
    			config_name = null
    			ConfigDescription =
    			ConfigName = CPU1_FLASH
    			CWD = C:\ti\workspaces\1100\sci_ex1_echoback\CPU1_FLASH
    			env_var = null
    			git_branch = null
    			git_dir = null
    			HOMEDRIVE = C:
    			OS = Windows_NT
    			OsType = win32
    			PathDelimiter = ;
    			PROCESSOR_LEVEL = 6
    			PROJECT_BUILD_DIR = C:/ti/workspaces/1100/sci_ex1_echoback/CPU1_FLASH
    			project_ref = null
    			PROMPT = $P$G
    			PWD = C:\ti\workspaces\1100\sci_ex1_echoback\CPU1_FLASH
    			system = null
    			system_path = null
    			SystemDrive = C:
    			USERDOMAIN = ENT
    			USERNAME = a0389327
    			windir = C:\WINDOWS
    			WROKK = c:\temp
    			xdc_find =
    			xdc_var =
    			XDCPATH =
    			XDCPLATFORM = null
    			XDCTARGET = null
    	ProjectSpec device-applicability:
    	Errors (0):
    	Warnings (0):
    There is a lot of info in there, including the version of the compiler and C2000Ware used.
    You can also get information at the workspace and product level, not just the project level.
    Please see the document I referenced earlier.
    ki
