I'm following the code for the ESMO and its not clear how Rs is defined as used in the ESMO routine. Is it phase resistance, phase to phase resistance, or the value you get when you measure resistance from Phase A to PhaseB/PhaseC tied together?
In ESMO_setParams it uses pUserParams->motor_Rs_Ohm but its unclear how to measure this value. In that same routine there baseVI is calculated and there is a 2.0f term in the calculation. I believe it has to do with Rs and scaling it but its not clear.
I am using the Universal Motor Project for my reference work on this which I got from the C2000Ware_MotorControl_SDK_4_00_00_00.
Can you help clarify this.
Thanks - Bruce
