Part Number: TMS320F280025
I am using the application note/application report "Online Stack Overflow Detection on the TMS320C28x DSP" to monitor the stack. I am also using a non-destructive RAM check (from the diagnostic lib). Of course, when the RAM check is checking the RAM where the the stack is located, the stack overflow detections triggers as the memory is written to.
Therefore I want to disable the watchpoint before the memory check and later reenable it. Unfortunately I cannot find any detailed information about the "Analysis Block" and how it works in detail. The only information I got is from the app note itself.
Based on that I tried this:
#define WP_EVT_CNTL (volatile unsigned int *)0x0000084E // WP0 EVT_CNTL register addr
void DisableStackOverflow()
*WP_EVT_CNTL = 0x001; // Write 0x0001 to EVT_CNTL to disable watchpoint
// of the watchpoint
asm(" RPT #1 || NOP"); // Wait at least 3 cycles for the write to occur
void ReenableStackOverflow()
*WP_EVT_CNTL = 0x002; // Write 0x0002 to EVT_CNTL to enable watchpoint
However, this doesn't work:
Although I am calling DisableStackOverflow() before the RAM check, I still receive the RTOSINT.
Can someone point me to the documentation I need? Or tell me if this is feasible at all?
Thank you very much,
Andreas
