IN PMSM example, there is a comment "EPWM4 ---> Not available for users if EnDAT / BiSS interface is active"
How can I make ENDAT/Biss inactive and use EPWM4??
Which example project are you using?
You can find the "POSITION_ENCODER" definition symbols in a "-Settings.h" file, and select the position sensor you used. And then you can use the EWPM for the other function if the EnDAT / BiSS interface is not used.
#define POSITION_ENCODER QEP_POS_ENCODER
