Hi Team,
How two understand these two comments in F2837xD_Gpio.c:
Thanks & Regards
Yale Li
Hi Team,
Thanks & Regards
Yale Li
Hello Yale,
All GPIO pins are set up as input by default according to the comment, most likely for safety in case a user does not configure the pin and tries to supply a signal to it. According to this comment, that's how the GPIO is initialized.
Omer Amir
Hi Omer,
Thanks for your reply.
It seems conflicted. The comment above seems meaning "enable pull-ups". But the comment below said "avoid enabling pull-ups". It makes me confuse. How to understand it?
Thanks & Regards
Yale Li
Hello Yale,
How I understand it is that the first comment says that all GPIO pins are by default set to input with pull-ups enabled. The second comment seems to be referring to the fact that there's a way to avoid doing this for all pins, or a 'hack', which is for when the user maybe does not want pull-ups enabled by default. Looking at the code in the file, it seems you can change the default to something else within that for-loop. I have not tested it before, but that's what it appears to be.
Omer Amir
