Part Number: CCSTUDIO-C2000
How can I search a register name on whole ccs project directory? I need to find where it is written. Is there any method?
thanks
thanks
Hi Gokhan,
If you know which IP you are modifying, you can open the Register View. It can be opened using CCS menu View -> Registers. There are two types of registers - CPU core registers, and IPs memory mapped register.
The changed registers will be highlighted with yellow background.
You just want to search the register, Technical Reference Manual is better place to start with.
Thanks & Regards,
Santosh
I'm trying to search a value or register while I'm not using debug mode. I just investigate the example projects in CCS. Sometimes, I get into a .c file in the project and I use ALT+Left Click to jump other .c files. However, sometimes after jumping another .c file, I see that its external void etc. I require to search it in the whole directory. Is there any method for this kind of issue?
I am not familiar with that. Please go through Code Composer Studio User's guide
https://software-dl.ti.com/ccs/esd/documents/users_guide_12.0.0/index.html
