Dears
Customer would like to double confirm if the instaSPIN ROM inside the F28027F is same exactly between Y19 and Y22 device?
Because customer found their product behavior run difference. The board with Y19 F28027F drive motor well, but the board with Y22 F28027F drive motor to be startup fail. They test several board with difference device and get the same behavior result.
The board are exactly same PCB design and same component value, all devices program the same .out firmware code. So customer suspect if the instaSPIN ROM is difference between Y19 and Y22 device?
