Hello, Every One!
I have some question about SDFM. After I config the SDFM,and cpu read the Results. I found that the Results is Convert Continuously,(DOSR = 128,SD Modulator Frequency: 16.666MHz), that means SDFM can Output a result every 7.68us. I Try use PWM1 Event-Trigger: ADC SOCA trigger but not successful. I want use every PWM midpoint(up-down mode)to trigger SDFM start Convert and after 7.8us output the result.
if any example exist in SDK to help solve this?
Another, When 280039C Run in 100MHz, How Can I Produce a PWM with 20MHz frequency and 50 duty cycle?
thanks a lot!
