Part Number: TMS320F28075
Dear experts,
for my work I am developping an application on the microcontroller Piccolo (TMS320F28075) for the motor control.
I programmed the CMPSS2 subsystem to perform a protection of the EPWM2 by means of tripzone.
Here below my settings:
Cmpss2Regs.CTRIPHFILCTL.bit.SAMPWIN = 31;
Cmpss2Regs.CTRIPHFILCTL.bit.THRESH = 30;
Cmpss2Regs.CTRIPHFILCLKCTL.bit.CLKPRESCALE = 2;
Cmpss2Regs.CTRIPHFILCTL.bit.FILINIT = 1;
I performed some experimental tests in lab in order to verify the effectiveness of my code.
I succesfully demonstrate that when I apply a DC current (130mA) higher than threshold (115mA), the tripzone forces high the PWM signal.
Therefore, everything works fine if I apply a step input signal.
Then, I performed some experimental test by applying a pulse signal with the same amplitude (the amplitude of the pulse is 150mA, again).
I verified that the subsystem CMPSS2 does not trigger the tripzone if the width of the pulse is lower than 10ms.
Moreover, I verified that the register Cmpss2Regs.COMPHSTS.bit.COMPHLATCH is always 0.
To sum up:
- everything works fine with a step input signal;
- the cmpss does not work with a pulse signal less wide than 10ms.
Why does the operation of CMPSS depends on the width of my signal?
I calculated that the width of the digital filter is (SAMPWIN+1)/(SYSCLK/(CLKPRESCALE+1))=32/(120000000/3)=800ns
Benito
