LAUNCHXL-F28069M: LAUNCHXL-F28069M with DRV8305-Boosterpack
Part Number: LAUNCHXL-F28069M
I am loading a simulink code through Matlab to a launchpad 28069m with  DRV8305-Boosterpack. I am following all the instructions as described here (https://www.mathworks.com/help/mcb/gs/hardware-connections.html#mw_8a869325-5b0d-4631-afd5-05a23622cc5c) the code is built and loaded successfully but the motor is not running while running the host model. I think the problem is about the jumpers' state. What do you recommend doing? because I burned one board before and I spent a lot of time and couldn't figure out this. I really need to move to another step. Thank you for your time and assistance.
  • You may try to follow the instruction on the link you mentioned above to set the switch, and check the output signals first without connecting the motor first.
    If you have any further questions about the simulink, you may post your questions on the Mathworks technical forum.
